Results 1 to 5 of 5
Scan tool that will do crank to cam correlation
This is a discussion on Scan tool that will do crank to cam correlation within the Shop Tools and Toys forums, part of the Technical / Maintenance category; Do you guy's have any recomendation on a Laptop based or hand held scan tool that i can check/set the ...
    Registered User shamrock246's Avatar
    Mar 2012
    middletown DE
    Do you guy's have any recomendation on a Laptop based or hand held scan tool that i can check/set the crank to cam correlation on my 97 4x4 burb i took the dizzy out to do the intake manifold gaskets the light was on for crank to cam correlation but moveing the dizzy in small incraments in the direction of rotation got the light to turn off and it starts fine and seems to run good with no light no pending codes
    any used ones i could look out for on ebay
    thanks
    Sean
    97 4x4 burb
    Jun 2012
    America
    Re: Scan tool that will do crank to cam correlation
    you can browse the related scan tool at Allobd2.com, I am its old customer, the scan tool is cheap and easy to operate.
    Texas, Where are you from TexasT's Avatar
    Jan 2006
    Texas
    What light are you turning off?
    Near as I can tell you are adjusting the timing. The crank to cam correlation is fixed by the timing chain, that may or may not be warn.Not adjustable as far as I know. You seem to be twisting the distributor body and adjusting the cam sensor and the timing. Am I way off?
    I use an auto xray because I used a friends a few times and found a good deal on one.
    http://www.autoxray.com/product_detail.php?pid=94 I paid less than half that for a new one. Works great for me.
    I have been looking at this one as it sez it does airbags.
    http://www.amazon.com/OTC-9450-Bilin...DateDescending
    Rich
    1994 C1500 Suburban
    1999 K2500 Suburban
    Why doesn't Buick ryhme with Quick?
    Registered User dave89iroc's Avatar
    Sep 2007
    SE Michigan
    Quote Originally Posted by TexasT View Post
    Timing on these needs to be set by using a scan tool to watch cam retard and rotate the distributor to set cam retard to 0+/-2 degrees
    2000 Silverado 6.0 4L80E 2wd
    Mar 2012
    middletown DE
    My light isn't on and there are no pending codes,i was looking to do the procedure that dave89iroc is talking about the scan tool has to have bi-directional control,i hear that the light can be off and the cam retard can still be out more than 0 +/-2 degrees,i was told that the OTC Genisys series does this a little pricey right know but if it will do everything i would need to do on this truck and on my other cars it might be worth it,i found some Snap-on mt2500's on ebay that are a good option but probably will not work on my newer cars,i bought the torque pro app to watch the ingition timing but i am still waiting for the bluetooth adapter,the laptop based ones i've found don't have bi-directional controll for the 97 but they do for the 98
    Sean
    97 4x4 burb
