Results 1 to 6 of 6
Max weight to haul in truck bed?
This is a discussion on Max weight to haul in truck bed? within the Tow/Haul Mode forums, part of the General Discussion category; 1999 silverado 1500 4x4 with 5.3l How much weight can I safely haul in the bed of my truck? I ...
    Chevy newbie 99silveradoLS's Avatar
    Dec 2008
    Missouri
    I need to haul a ton of lime to be dumped on to a food plot I'm making for the deer this weekend and need to decide if I need to borrow another truck or not to haul it.
    1999 Silverado LS 4x4 Z71 w/ 5.3L
    I'm so much cooler online Mark13's Avatar
    Nov 2006
    Northern, Illinois
    Re: Max weight to haul in truck bed?
    Are you talking ton as in 2000lbs or as in a large amount?
    2006 Chevy 2500HD
    Boss 9.2 Poly V plow
    Piloting the Land Yacht Texsbluethunder's Avatar
    Feb 2006
    Alliston, Ontario, Canada
    Depending on how far you are driving and the type of terrain you can do it. I have hauled 2500lbs+ in my 96 1500hd, but that was for a little over a mile and on flat ground.if its going to be spread evenly over the whole bed that makes a big difference too.
    '96 Chevy K1500HD ECLB, 385,000km and still goin strong...ish, Rebuilt 355 w/4L60e on its last legs
    '07 Pontiac G5, Wifes Blurple commuter, 97,000km
    78/80/93 GMC in many pieces and places waiting for time and effort.
    Dec 2008
    Missouri
    I literally mean a ton...2000 lbs. I'd have to haul it about 15 miles with a few steep grades in between. I think I'll just see if I can borrow my dad's cummins and not worry about it.
    Thanks
    Apr 2004
    Grand Rapids, MI
    I've estimated that I hauled about 1000lbs of my brother-in-law's junk from Michigan to Florida, and it was a breeze. My guess is the max payload is between 1500 and 2000, so you'd probably be OK. 15 miles isn't all that far, you could probably safely haul it all at once, but you could also make two easy trips. I would personally lean toward two easy trips, depending on how big those hills are, or rent/use a trailer.
    I've had my truck overflowing with mulch before. I don't recall how much it was - maybe 4 cubic yards - and certainly don't know the weight, but that was just about my limit for comfort. The truck handled it fine, but much more than that and I'd be worried about wear and tear.
    '01 Chevrolet Silverado Z71 ECSB
    Feb 2006
    Quote Originally Posted by 99silveradoLS View Post
    Thanks
    Well 2000lbs loaded evenly in the bed should be okay, as long as you have good tires.
