Page 1 of 2 12 LastLast
Results 1 to 20 of 29
LIFTED with 35's TOWING QUESTION???
This is a discussion on LIFTED with 35's TOWING QUESTION??? within the Tow/Haul Mode forums, part of the General Discussion category; Ok here's my question I have a 5.3 ltz with 3.73 gear 8"lift and 35tires/20wheels, Im going to take a ...
    Jul 2009
    FL
    Ok here's my question I have a 5.3 ltz with 3.73 gear 8"lift and 35tires/20wheels, Im going to take a trip up to Tenn. mountains (windrock/coal creek) with my rhino(1200# rhino and probably 13-1500#single axle trailer)
    should I worry about the strain on the trans or will it pull just fine without temps to high? I obviously know it can tow it, it's not the load Im so much worried about but the length of time driving with the load tire/wheels this is a 12hour trip there and 12hour trip back, would you guys do it with this set up(tires/wheels/lift)? or am I just worrying to much??? A couple of buddies say that Im crazy this is nothing for this truck but it's long trip and I have heard horror stories with over working the tranny??
    thanks
    2008 5.3 Silverado LTZ 4x4
    8"lift with 20x10 BMF wheels/35x12.50 Toyo M/T electric steps
    2008 Wrangler front/rear Electric lockers 4.88's 33"toyo
    Registered User rebelbowtie's Avatar
    Aug 2003
    Re: LIFTED with 35's TOWING QUESTION???
    i think it will be alright. do you have a trans temp gauge for piece of mind. where in florida do you live?
    Jul 2009
    FL
    I have the digital one on the truck and also the one on my programmer.
    Aug 2003
    then i say go for it. just use common sense and dont let it get over 210 ever. once you go over 210 the heat cuts the fluid life in 1/2 by e every ten degrees. you end up with a smoked tranny fast
    Jul 2009
    FL
    yeah that would suck, well I guess I have no choice either way if I want to get up there to ride in the mountains, I thought about renting a tahoe just for the trip avoiding the wear and tare on my own vehicle but they are freaking nuts $1600-1700 for a week or so rental.
    Aug 2003
    sick rhino btw. just needs some snorkels.
    Jul 2009
    FL
    thanks I appreciate it!
    Aug 2003
    i like that back seat. looks nicer than most of the ones i've seen for side by sides
    Jul 2009
    FL
    Quote Originally Posted by rebelbowtie View Post
    its actually a full suspension seat, nice and comfy for sure, it's got springs and cushions or something like that in it.
    Registered User smokinsilverado's Avatar
    Aug 2008
    Washington
    You shouldn't have any problems, like rebelbowtie said just watch the temps, but your not pulling a lot of weight so you should be good to go
    ****FOR SALE****05 Silverado 5.3, Whipple , Nelson tune, JBA Shorties, 80mm BBK Throttle Body, 6" Tuff Country lift, Toyo MT's 35's rolling on 20" MHT Fuel Hostage Wheels, Eclipse Avn62D Navi with 2 small 8's
    loves Mickie James oldred95's Avatar
    Mar 2004
    Kiowa, KS
    An 08 crew cab should have a 6 speed auto correct? If so you should be able to get along just fine. Keep it out of 5th and 6th as needed and keep an eye on your temperatures. The 6L80E has an insanely low 1st gear as it is so even with the tires it shouldn't be too bad if you have to do some climbing.
    1995 Silverado - ported vortec heads, 4L80E, efans, LT4 Hot Cam, Rear disc brake conversion w/drilled and slotted rotors
    1999 NBS Silverdo - transgo HD2 shift kit, 3 inch dynomax ultra flow, Ford keys and 305/70-16 Mickey ATZs
    Nov 2008
    Portland, OR
    You can tow in whatever gear you want. The tranny only really builds heat when the converter isnt locked. So if your locked and it doesnt seem like your working the piss out of your motor your fine. I tow in OD on a regular basis as long as the converter is locked. You should be golden with that trailer, probably wont even notice its back there.
    Registered User armystud999's Avatar
    Oct 2008
    Fort Rucker, AL
    Your truck is BA dude!
    97 Yukon 2dr, 6" lift, 35 toyo open country M/T, 4.56, Yukon Locker, Black Bear Tune, Flowmasters, WAY too much to list...
    03 Honda CBR 954RR Custom paint, chrome, stretched.
    05 Honda TRX 450R Stock
    70 Chevy C10 Short bed "Restored" **SOLD**
    72 Chevy C10 Long Bed**SOLD**
    Jul 2009
    FL
    Quote Originally Posted by armystud999 View Post
    thank you!
    Redneck with dip!
    Jan 2009
    Kent City, Michigan
    Did you make that seat yourself? Id like to know because I have the same Rhino, Ducks Unlimited 700fi, same tires but Im running the chrome and black SS wheels. Just wondering how you did that.
    Badass Rhino and Badass truck
    1997 Silverado 1500 4x4 RCLB
    Hedman LT's, Thrush welded, EGR delete, K&N, 4.10s, 285s, Fosgate P3S 12", Pioneer components-SOLD
    1990 Dodge W250 RCLB Headache rack, Spectra intake, 4" straight pipe, 3200 governor springs
    Vekster vekster101's Avatar
    Jul 2005
    CANADA
    Quote Originally Posted by Hatfieco View Post
    how do you know when your converter is locked?
    Sorry for the thread jack.....awsome looking truck though!
    1998 ECSB Chevy Z71, DUALS, K&N, 6" RCD, AAL, Atlas 16x8, 315's Toyo M/T's**STOLEN AND BURNED**
    2006 GMC CCSB, bone stock at the moment- Soon to be Lifted**NEW RIDE**
  17. #17
    Jul 2009
    FL
    Quote Originally Posted by hunters_chevy View Post
    Thanks I appreciate it! No I didn't make the seat myself, you can purchase the seat and bracket from rhinogiant.com and the cage I had made in California and sent to me.
    Sorry these are the best pics I have of it right now.
  18. #18
    Jul 2009
    FL
    Quote Originally Posted by vekster101 View Post
    Good questions? Id like to know myself, I think???? I can tell??
    Oh and by the way the truck tows awesome I really don't even know its back there.
  19. #19
    Aug 2003
    you can notice a drop in RPM on the tach when the converter locks. sometimes a really tight converter will lock and feel like another gear. but on the stock set up you cant tell. btw where do you go riding? you ever run out at river ranch or triple canopy?
  20. #20
    Jul 2009
    FL
    So are there any ill effects to getting a better converter?(like getting worse gas milage or something)?? or is it worth getting one? I ride out in bonita springs(45min away) or out of state usually, Im 2 1/2 hours away from river ranch and have never been but have had tons of invites just no time.
