Results 1 to 9 of 9
Can I tow a 26ft 5th wheel trailer/camper with a 1/2 ton 5.3L Silverado?
This is a discussion on Can I tow a 26ft 5th wheel trailer/camper with a 1/2 ton 5.3L Silverado? within the Tow/Haul Mode forums, part of the General Discussion category; Forgive my ignorance here, but my knowledge on towing and weight are rather limited. I am looking at buying a ...
    Mar 2011
    Wylie, texas
    Forgive my ignorance here, but my knowledge on towing and weight are rather limited. I am looking at buying a new 26ft 5th wheel camper with 8600lb GVWR. I have a 2005 5.3L crew cab, short bed Silverado. I think this is the same as a 1500. I currently pull a 24 ft bumper pull camper with somewhere around a 7500 GVWR. I have no problems with pulling this and was told that a 5th wheel would actually be an easier pull. My question is, is this 5th wheel within my towing rating and would it be safe? Of course, the camper dealer says it is perfectly safe and within the ratings, but I'd rather hear from someone unbiased and really in the know.
    Thanks in advance for any help.
    Get in sit down hang on. SolMan98's Avatar
    Jul 2003
    Dallas, GA
    Re: Can I tow a 26ft 5th wheel trailer/camper with a 1/2 ton 5.3L Silverado?
    I'm going to say you will be overloaded, but start with the basics, what is the GVWR on your truck? What gears?
    D/D-2006 HHR 1LT 5-Speed.
    1996 Silverado, 5.7, FIPKII, Elect Fans, S/S Headers, Duals, Wait4Me, 4/5 drop on 18" Weld Evo Velosity's. STOLEN ON 9/9/2006
    Jan 2008
    Canton, MA
    your hitch weight with the 5er will bring your truck very close to its gvwr. also if your truck bed is under 6.5feet youll need to invest in a pricey sliding hitch to clear your truck cab while turning. if you do purchase the camper i wouldnt tow it without helper springs or airbags.
    Registered User Drumaniac3000's Avatar
    Jun 2004
    Here
    Quote Originally Posted by Neil814 View Post
    Yep- I'm not sure if there is even a hitch available for the 1500 CCSB platform. Many 6.5' bed trucks need a slider to function let alone an even shorter bed. You may be limited to a bumper pull trailer.
    The opinions expressed above are purely my own.
    Registered User TiredFarmer's Avatar
    Feb 2010
    Waynesboro, Tennessee
    Can you - YES
    Should you - NO in my opinion. If you have the 3.73 gears behind the 5.3l you are pobably at 6400lbs GVWR, at max for a half ton (1500) would be 7200lbs.
    Towing 8600 lbs IS overloaded, regardless of hitch type.
    A fifth-wheel WILL tow easier, turn easier and back easier than a bumper pull; but you need more truck!!!
    00 k-1500 ECSB 5.3 4l60e, Z71, 231,500 miles. TRADED 5-2013
    03 2500HD ECSB 6.0 4l80e, 4.10 gears G80, 165,000 miles.
    05 K2500HD ECLB 6.6l LLY, 5speed Allison, 270,700 miles (Got 5-2013) SOLD 7-2014 at 299,876 mi
    08 K3500HD CCLB Dually, 6.6l LMM, 6 sp Allison, 3.73 gears 183,000 miles
    Registered User TylersZ's Avatar
    Nov 2010
    mobile alabama
    i'd say don't personally...
    Registered User ToyHauler's Avatar
    Jun 2006
    Western NY state
    those camper weights seem awful high for there length, are they toyhaulers? not that it makes any difference just curious
    99 GMC Yukon SLE 4dr
    KYB monomax, air lift, tekonosha, reese dual cam, bfg at/ko
    87 Firebird, 07 Monte Carlo lt, 08 lucerne cxl
    Nov 2009
    AL
    8600 if that is what is tagged on the side of the fifth wheel that is the gross not its actual weight. If your listening to guy at the camper dealer they are more often wrong then right. Most of the new camper tags have a cargo capacity on the side. I was looking at camping world and 80% had a cargo capacity under the GVW rating. If the 5ver your looking at has this subtract the cargo capacity of the 5th wheel from the gross and that is the dry weight. Also is this 5th wheel a 1/2 ton towable unit. If this is the case you won't have any issues. As they move the axles forward to get the weight off the truck.
    CCLB dually, LS-1 Injectors, Airaid Intake, Magnaflow 2.5 dual in/out, Derale Cooling Tube Pan, B&W 24K super cooler[
    Full Size Chevy Fire Dept Chevy Fireman's Avatar
    May 2007
    Brewster, Ma
    Quote Originally Posted by TiredFarmer View Post
    Can you - YES
    Your truck will hate you for life.
    1995 K1500 Step-Side
    Silent R's Racing
