The rating on my factory hitch says "12000 with weight distribution hitch"
This is a discussion on stock hitch ratings. within the Tow/Haul Mode forums, part of the General Discussion category; Well im starting to pull more then just a car here and there, im starting to pull 2 - 3 ...
Well im starting to pull more then just a car here and there, im starting to pull 2 - 3 horses at a time and possibly gonna be putting a gooseneck in my truck. the question is, how much can the stock hitch handle? the stock ones has handled a **** load but after reading around im kidna concerned. I have towed 1 ton SRW trucks with a equipment hauler and i have towed a 2.5 ton axle truck with the stock hitch and never ever had a issue. So whats the deal? i know alot of people said they are weak but i never had a issue. (knock on wood)
'97 Ford F250 ECLB, 7.3/ZF5. Tow Pig
'98 Chevy K1500 ECSB, SAS
'94 GMC C1500 RCLB, DD
Some guys think that if you got a cooler car that your better then other guys; Those guys are right. - Adam Farrara
2001 silverado 5.3 flowmaster with dual outlet dumps black on black with black windows
What truck are you talking about kugs? The stock hitch on my 3/4 ton is rated at 7,500k without W/D and 12k with W/D.
05 Cavalier
Half the problem is your saying I want to know the hitch rating for my truck? So what kind of truck do you have? If it's the half ton in your sig and that's what your pulling a 1 ton with, buy a new truck that's actually rated for that weight.
With a W/D the stock hitch will rip apart literally.
This is the ratings of the stock hitch on my 03, 3/4 ton.
05 Cavalier
I've never had any issues....
Consider yourself lucky.
My 92's hitch was 500lbs tongue 5000lbs total.
OE hitch on my 07 says 600lbs tongue, 6000lbs total, even though the tow rating is 9600lbs for the truck.
That's not GVWR, that's max tow rating. GVWR is only around 7800lbs IIRC. Tongue weight contributes to GVWR, trailer weights contribute to GCWR.
In your example, the truck with a full tank of fuel, and just the driver would be over GVWR with just a 5Klbs trailer, let alone the fat girls... doesn't work that way.
So i should find a 3/4 hitch or a 1 ton hitch? because i haven't had a issue towing any of the stuff. and now im gonna be SAS it and still plan on hauling horse trailers and what not.
so 3/4ton or 1 ton would do it for me? or simply won't fit?
you dont want to get a used oem one if thats what your asking.
this is good to 10k with WD(classIV);
http://www.amazon.com/Curt-Manufactu...ar=1&carId=001
class V;
99 GMC Yukon SLE 4dr
KYB monomax, air lift, tekonosha, reese dual cam, bfg at/ko
87 Firebird, 07 Monte Carlo lt, 98 Bonneville SSE, 04 F550 CC 4wd service body
How about sell the truck you have and buy a 3/4 or 1 ton, then buy a hitch for that.
If your going to pull alot it is well worth the money.
Also just because you have not had problems does not mean it's smart.
05 Cavalier
would you like to donate money to me then i cant even afford my sas but i go little by little.
And thats how you should tow. You are asking smothing of a truck that it wasnt never meant to do and when **** starts breaking and/or you can stop you might understand why so guys are telling you to get a bigger truck. Like ive said ive done it a pinch and it was for a short distance. A gooseneck was never meant to be i a halfton yes i know it wil fit doesnt make it right.
Why don't you forget the SAS and save the money for the truck.
I saved my money so I could buy mine. No reason for me to give you any of my money so you can buy a truck. When your overloaded and hit me, I'll just sue you and buy the next truck so I can step up the to trailer I want.
Like Kugs said there is a reason why people are telling you to buy a hitch. I don't remeber or know if you even said how much weight your pulling. But pulling alot your so much better off with a 3/4 ton.
As it is your asking about the hitch rating and in the same breath saying well I've overloaded it for the past 5 years and haven't had a problem why do I need a new one?
A couple hundered for a hitch bought and installed locally is nothing compared to killing someone and or going to jail because your hitch failed.
05 Cavalier
Don't be a nimby!! Sell that freaking truck or stop towing that much weight. Regardless of what hitch you have your ENTIRE truck is overloaded!!! Stop before you kill yourself or someone else. Don't listen to people that say "oh I towed this and that with a 1500 and it was fine" it's not fine. It's ignorant.
/thread
