Results 1 to 3 of 3
E load vs G Load
This is a discussion on E load vs G Load within the Tow/Haul Mode forums, part of the General Discussion category; I have an 84 crew cab wedgeback car hauler. 30ft long, 18ft deck that I haul my Jeep on. I ...
    Feb 2011
    SC
    E load vs G Load
    I have an 84 crew cab wedgeback car hauler. 30ft long, 18ft deck that I haul my Jeep on. I got a good deal on the front tires but it is time for some rear tires now. Do I need to use the G Load tires or will E Loads hold up? The truck weighs 8000lbs empty, the Jeep should be 4-4500lbs, plus gear and people for a trip.
    The tire guy told me the E loads are rated to 3100lbs each in a dual set-up, and the G Loads were 3400lbs each in a dual set-up. With only a 1200lb difference in load it doesn't seem to make sense to spend $1000 more for 4 tires.
    I may be getting ready to tow my son's truck also, but that should be no more than another 500lbs on the truck. I do plan on adding firestone airbags to help raise the back up. It tail drags bad even empty.
    Any help or insight would be a great help. I posted a small pic of the truck when I bought it.
    [IMG][/IMG]
    World's Tallest Midget TheBigMortboski's Avatar
    Jan 2012
    Seattle/Twisp WA
    Re: E load vs G Load
    I didn't realize you could still get G-rated tires in a 16, except for trailers. That isn't a 19.5", is it? I can barely see.
    Yeah, go with the E-rated ones. I've seen dudes haul much more with 10 plys than what you're going to do.
    Registered User TiredFarmer's Avatar
    Feb 2010
    Waynesboro, Tennessee
    Load range E tires will be fine for you!
    00 k-1500 ECSB 5.3 4l60e, Z71, 224,000 miles and counting.
    03 2500HD ECSB 6.0 4l80e, 145,000 miles. A towing master!
