Results 1 to 6 of 6
How did I remove this?
This is a discussion on How did I remove this? within the Tow/Haul Mode forums, part of the General Discussion category; I grew up on a farm, neither myself or my friends know how to get this thing out, I would ...
    Registered User Gumbo Mud's Avatar
    Nov 2009
    Houston
    I grew up on a farm, neither myself or my friends know how to get this thing out, I would like to keep it installed on the truck, but need the ball removed for a new paint job. Any clues. As you can see from my horrible pics it appears to just screw into the nut on the bottom plate. Thing is as I turn the ball on the top neither the nut or the stud turn any clues?
    LR4 Outlawz2004's Avatar
    Mar 2008
    Louisiana
    Re: How did I remove this?
    does the plate spin? Maybe keep turning the ball, the threads may have broken in the middle of the stud leaving the bottom appearing to not turn.
    Nov 2009
    Houston
    Its possible but ive made about 10 full turns or more with what appears no gain.
    Registered User bowtieguy101's Avatar
    Nov 2009
    mobile al
    Turn the ball with a pipe wrench, The plate does nothing to remove the ball.
    1995 chevy street pounder project.
    1987 Chevy 2500 Crew cab short bed 4x4 project.
    2005 Yamaha FJR 1300 (daily transportation)
    Registered User Jon4x4's Avatar
    May 2010
    Deland, Fl
    i agree just turn the ball
    '97 Ford F250 ECLB, 7.3/ZF5. Tow Pig
    '98 Chevy K1500 ECSB, SAS
    '94 GMC C1500 RCLB, DD
    Some guys think that if you got a cooler car that your better then other guys; Those guys are right. - Adam Farrara
    Registered User TiredFarmer's Avatar
    Feb 2010
    Waynesboro, Tennessee
    You should be able to turn the ball with a pipe wrench and get it off. Worst case scenario, use a torch on the underside and cut the nut off, then buy a new ball with nut and lockwasher.
    00 k-1500 ECSB 5.3 4l60e, Z71, 224,000 miles and counting.
    03 2500HD ECSB 6.0 4l80e, 145,000 miles. A towing master!
