Sounds like you need new shocks and the leaf pack replaced. Neither load should make that truck squat very much, as tongue weight should only be 10-15% of total towed weight.
You have a proper receiver hitch and are towing with your tongue/load as level as possible?
The V6 is fine for pulling both of those, but if you want some more grunt, you may want to look at changing gear ratios, some V6's came with 3.23s, which can be pretty sluggish.
LinkBack URL
About LinkBacks
