Yeah wind is a real mother f*cker!
This is a discussion on Wind sucks (and blows) within the Tow/Haul Mode forums, part of the General Discussion category; I went on my first (trailer) camping trip last weekend. I have a 2004 2500-nonHD with 3.73 rear end. I ...
I went on my first (trailer) camping trip last weekend. I have a 2004 2500-nonHD with 3.73 rear end. I went about 120ish miles on Friday evening. The trailer is a jayco hybrid at about 4200lbs. Obviously the truck pulled like a beast with that load. With an additional 2000lbs of people, dog, gear, etc - good times. Used tow haul mode and was able to keep it in OD at 65mph. Probably got 11-12mpg.
The trip home sucked though. The wind blew 40mph with gusts of 50 or so. It was all crosswind. I drove mostly at 50-55mph and it only left third gear to find 2nd. I have sway control and didn't have a lot of sway to deal with, just a constant push to the driver side. I got just under 8mpg on the way home.
Is that just the way it is in the wind- slow down and take it? Anything I could do to make a trip like that better, other than not going?
Yep. Nothing you can do, if it's bad enough you need to stop and point into the wind.
05 Cavalier
Nope, nothing you can do.
Also, super-jealous that your 6.0L got 11-12 MPG. Mine only broke 9MPG going downhill, unloaded.![]()
'04 CTS-V | CS Diff Bushing | ALRADCO | 180* T-stat | Revshift MM's | Revshift TM | BMR Pinion Brace | 245/45R18 BFG Comp-2's
''00 MR2 Spyder | 225/45R16 - Rear, 215/40R16 - Front BFG KDW's | 138hp
I am the master of my fate; I am the captain of my soul.
campers are like pulling big parachutes
99 GMC Yukon SLE 4dr
KYB monomax, air lift, tekonosha, reese dual cam, bfg at/ko
87 Firebird, 07 Monte Carlo lt, 98 Bonneville SSE, 04 F550 CC 4wd service body
