Results 1 to 5 of 5
factory GM trailer light wiring...
This is a discussion on factory GM trailer light wiring... within the Tow/Haul Mode forums, part of the General Discussion category; I found today I have a problem with my factory 7-pin trailer light setup on my 04 Sierra...the only thing ...
    hucking fates this server FordeatinZ71's Avatar
    Aug 2002
    your mom's mobile home...
    I found today I have a problem with my factory 7-pin trailer light setup on my 04 Sierra...the only thing that works is the running lights, the brake lights and turn signals are inop. I checked the underhood fuses that were clearly marked for trailer, only found two, and they were fine. Also checked the two maxi fuses I found (one was a dummy fuse from factory, shouldn't affect my setup...but I swapped in a good one anyhow) and they were good. I checked obvious wiring I could see and it looked fine...
    The truck has a warranty so I'll probably just let the dealer fix it, but I don't wanna take off work to drop it off so I'd like to fix it myself if its something simple...any ideas guys?
    2004 GMC Sierra SLE Z71 rcsb, 5.3/4L60E/3.73/G80 time bomb...3" lift, tinted 03+ Silverado tails, plasti-dipped 16" wheels (unknown brand), 285/75/16 Thunderer M/T Extremes, Thrush Welded muffler...
    Feb 2007
    alexandria bay, ny
    Re: factory GM trailer light wiring...
    make sure you plug the trailer into another vehicle to make sure its not the trailer. i had a similar problem with a trailer i had, turned out to be a bad ground on the trailer
    Aug 2002
    Actually I spliced into the actual taillight wiring and the trailer works fine. Just need to fix this factory crap. Thanks though, that's something a lot of people might not think to check!
    Registered User ToyHauler's Avatar
    Jun 2006
    Western NY state
    so its probably in the connector, sometimes the terminals are corroded, some times the wires are, not in the best place. i use spary stuff when, sorta like terminal spray to seal the wire connections in the connector before i put it together.
    99 GMC Yukon SLE 4dr
    KYB monomax, air lift, tekonosha, reese dual cam, bfg at/ko
    87 Firebird, 07 Monte Carlo lt, 98 Bonneville SSE, 04 F550 CC 4wd service body
    Aug 2002
    Yea, you're probably right...its going into the shop soon...
