Results 1 to 10 of 10
Considering an engine swap (has to do with towing)
This is a discussion on Considering an engine swap (has to do with towing) within the Tow/Haul Mode forums, part of the General Discussion category; Hi guys, new here. I have a 1992 c2500 with a 454 and 3.73 gears. I bought this truck with ...
    Aug 2012
    Gadsden, AL
    Hi guys, new here.
    I have a 1992 c2500 with a 454 and 3.73 gears. I bought this truck with towing my boat to the Gulf and back in mind. About 350 miles each way. I also usually drive it daily. The boats a cabin cruiser. Not sure about the weight, but I'm getting 7.8 mpg towing it. Needless to say it doesn't take long to add up. I spent about 350.00 on the last trip (just gas for truck). I like the power of the 454 but am considering swapping for a 350 throttle body engine. The truck has a 4L80E transmission. I'm wondering what kinda mileage gain I'd be be looking at. Or possibly a vortec engine. I've done a lot of searching here and haven't found the info I'm looking for.
    I'm hoping I'm posting in the right forum. Thanks for any info.
    Jun 2012
    eastern PA
    Towing, both motors would get around the same. Just driving the 350 will get a little better MPG. The 454's usually get the same MPG regardless if towing or not. If you do go 350 definitely look for a vortec
    Aug 2012
    Gadsden, AL
    Re: Considering an engine swap (has to do with towing)
    Quote Originally Posted by 19trax95 View Post
    Really?? My brother had a 93 k1500 and says he got 16-18 mpg on the hwy (without tow). I would have thought a vortec engine would do much better without a load and at least a few mpg better with a load. That doesn't make sense...
    Registered User Chriscon7's Avatar
    Jun 2011
    Colorado
    By vortec do you mean LS series motors? Cause a 6.0 swap would net some gain I suppose
    06-2wd-4.8-5speed-LR4-Z85-40series-Baja 8s-TrueTrac-4.30gears-J&S Performance Tune
    http://www.fullsizechevy.com/forum/i...2006-rcsb.html
    Aug 2012
    Gadsden, AL
    Quote Originally Posted by Chriscon7 View Post
    I'd kicked around the idea of a 5.3 actually. Local yard has an 05 for about 750, with about 80,000 miles. My dad has an 07 silverado extended cab with a 5.3 vortec and it pulls the boat fairly well.
    Oct 2007
    TN
    DDing a 454 sucks for gas, towing still sucks gas, but hears a question for you.
    You said you got around 7.5 mpg pulling the boat, what do you get unloaded?
    That 454 will not have to work as hard as a small block be that a 5.7, 5.3 so your mileage towing will go down less with a 454 then with a small block. Thus your towing mileage would be about the same eitherway.
    05 Cavalier
    Aug 2012
    Gadsden, AL
    Quote Originally Posted by kcb37 View Post
    I'm not sure on the unloaded mileage. I haven't checked it, but I think around 10 is normal with my setup.
    Dec 2011
    river ridge
    My 1/2 ton 2wd 1998 Suburban-fancier fuel injection system and Vortec motor-5.7 gets 20 mpg at 60 mph-maybe 19mpg at 67mph
    The same year 454-figure maybe 13mpg at 60 12 mpg at 67mph.
    I rarely tow- but spark ignition motors in 1/2 ton 3/4 ton all seem to get about 7-9 mpg when they tow heavy-6000-7000-8000 lbs.
    Bottom line-don't make this engine switch to get better towing mpg.You'll be lucky to get 1mpg better with the 5.7 while towing
    Figure -best case 8 mpg 700 miles=87.5 gal x $4/gal =$350
    5.7 best case 9mpg 700 miles= 77gal x$4/gal =$311
    So you save $39 per trip AT BEST
    12 trips per year =$450/yr
    Figure all up it will cost you close to $1500 plus LOTS of work
    4 years to break even
    AND you might not actually get better mpg towing-you probably would if you kept your speed down- but that 1 mpg better-pure guess and nothing I would count on.
    The whole time you would have a somewhat "less good" tow motor
    I'm a MPG nut-but I think your best bet is to drop 5-7 mph off your tow speed-you'll get the same improvement in mpg-add maybe 50 minutes to trip time on each leg?? But less stressful trip since slower tow is easier tow(unless folks are running up your tailpipe-which maybe they will on interstate??
    Luck
    Charlie
    PS No good way to get good mpg towing a heavy boat with a spark motor-other than slowing down-or a really modern-expensive turbo diesel($50,000) or maybe that Ford 1/2 ton 3.5 twin turbo spark motor($30,000+)
    Drop your speed if it is safe on your hy and you have the time.
    If you go to a SBC- get the most modern one you figure you can get to work in your truck-the 5.3 of some vintage-might add a bit more mpg towing-geared right-
    Aug 2012
    Gadsden, AL
    Quote Originally Posted by phoebeisis View Post
    Luck
    Charlie
    Thanks for the information. I've milked all the mpg out of the 454 I could. I maxed the air pressure on the trailer and truck tires and do run pretty slow on the interstate, 58 to 65 mph unless going down a hill. I'm thinking I could save a lot of money when not towing, and like you said, prolly save a fair amount towing with a 5.3 vortec. I love the 454 power but it sure is expensive...
    Dec 2011
    river ridge
    I'm a mpg nut-I mildly hypermile(Pulse and glide in city-max sidewall tire pressure-and shut it off at redlights and stopping at bank lines- if I think the light is over 40 seconds-that is since I replaced my older starter-you gotta consider your starting/charging system on old vehicles when you do the arithmetic on saving the .6 .7 gph my 5.7 uses-your 454-wow-it might use 1gph at idle)
    I have a scangauge-plug it into OBDII port-gives instant mpg or Liters per KM- rpms water temp-advance-load-throttle position(I think) lotta other stuff-also is a code reader. They won't work on the OBD1 you have-but would work on a 5.7 if you did a complete switch to a 96-99 5.7 or a 5.3 if you did an entire switch-ECM wiring harness-fuses-everything
    I think it would be much easier to put a Vortec 96-99 5.7 in-even easier to put a TB 5.7(but they are waaay down in power vs 96-99)-than the 5.3-
    But the 5.3-especially 2002 ( 2wd rated 13/17 EPA 2wd) or 2004( 2wd EPA 14/18) are inherently more efficient than the 96-99 2wd 5.7-12/17 EPA which my 1998 Suburban is-
    But pretty sure the 5.7 will be easier to install-and thru 2003-the 5.3 and 5.7 have ALMOST the SAME EPA.2000 5.3 is the same12/17 2001 is 13/16 I think 2002 is 13/17-
    The 2wd 2004 5.3 (EPA 14/18) is when the 5.3 clearly has a big edge-2 city 1 hy-MPG edge over the 96-99 5.7.
    Now SOME of that might be aerodynamics-tires-some sort of tuning-never got clear answer on why the 2000 5.3 had same EPA as the 5.7??
    My point-the 5.7's will give MOST of the mpg improvement of the 5.3-so something to consider(the earlier 5.3 had that funny piston slap like noise-didn't hurt the motors but hurt resale)
    The 96-99 5.7's don't seem to have any quirks-teething problems-just the intake manifold gasket stuff-supposed to be cured with the latest FelPro fancy SS and silicone gaskets.
    Yeah-you could certainly get better "not towing mpg" with the SBCs-maybe 3-4 mpg hy-2mpg city
    You will probably miss that UMPH-of the 454-all accounts 454 nice tow motor
    And gasoline is probably going to stay in the "nearly $4" range for a long time-our economy MIGHT be able to tolerate $4.50-so we can expect the speculators to drive up the price-especially if the chinese economy recovers from the little downturn they are apparently having.
    Yes-GASOLINE-fuel- is going to be a real problem for most folks for a long freakin time-
    On the bright side-in 10 months-62 ss- I'll have a little more $$-so I'll save my pennies and see if I can get a 2004 Suburban when someone foolishly sells or trades it for a crossover to get better mpg
    Trying to look on the bright side of paying $4/gal- not much bright side other than lower prices on used 9 year old Suburbans!
    Luck
    Charlie
