Results 1 to 4 of 4
94 gmc tbi to tpi swap
This is a discussion on 94 gmc tbi to tpi swap within the Engine Swaps forums, part of the Projects and Builds category; hey guys, I just bought a tpi setup and was wondering is my computer capable of running this multi port? ...
    May 2009
    surprise, az
    hey guys, I just bought a tpi setup and was wondering is my computer capable of running this multi port? if not then is there a way to run both computers? reason is I don't want to spend more money on swapping trans. also is there anything else I should be on the lookout for? this system came with the tpi harness/computer, and lti fuel rail/injectors, and harness. what should I do? my engine is to modified for the holley tbi to run it correctly.
    94 gmc sierra xcss 4" lift on 33's. forged 383 stroker, pacesetter LT's true duals with x-pipe and dual 40 series, built 4l65e, 14 bolt SF conversion, and 6 lug conversion.
    That guy adam.binkley's Avatar
    Jul 2008
    Nashville, TN
    Re: 94 gmc tbi to tpi swap
    Take a look at this site
    I'm in the process of collecting the parts for my tpi swap right now.
    1994 C1500 SCSB 350 4L60E....
    1999 Ford Ranger
    Jun 2011
    Nacogdoches, TX
    Supporting Gold Member GreaseDog's Avatar
    Dec 2004
    Elkhart IN
