Page 3 of 7 FirstFirst 12345 ... LastLast
Results 41 to 60 of 132
budget sas 93 silverado
This is a discussion on budget sas 93 silverado within the Projects, Builds & Restorations. forums, part of the Projects and Builds category; im not sure actually, its bolted up stock to the leafs, its negative castor not sure how much though, its ...
  1. #41
    93 silv 4x4355 5spd
    Dec 2005
    pittsburgh pa
    Re: budget sas 93 silverado
    im not sure actually, its bolted up stock to the leafs, its negative castor not sure how much though, its just when i turn the wheels the truck actually leans with turn in park, and u can hear the pump working to turn the wheels, also my camber is horribly negative so this may be the cause instead, im not sure how to check specifics its just by eye
    355 coming back out!
  2. #42
    Newbie silver98Z71's Avatar
    Oct 2006
    Tifton, GA
    Go get an angle finder and place it on the steering arm. That will yield the most accurate caster measurement. My truck leans when I turn too, I have no swaybar and the draglink is leaning the truck left or right depending on which way I turn the wheel; it's just that way. You also hear the box strain because you're turning the tires with massive amounts of friction between the tires and parking surface. Roll when you turn and it sounds much mo' betta.
    -Daniel
    1998 K1500 L31/4L60e/241/8.5/9.5
    Bogger Chapter
    Some people are just educated beyond their intelligence.
    -Jerry Clower
  3. #43
    93 silv 4x4355 5spd
    Dec 2005
    pittsburgh pa
    okay thanks for the info i guess im just paranoid since i dont know how the suspension should be reacting with a sas
    my castor does look normal. but my camber is def off as well as my toe.
    my steering box is bad and the truck is a death ride on its first run.
    theres so much slop in it, and i tried to tighten the box and it made it worse
    so i ordered a a new box.
    but i def need a swaybar i dont even have a track bar nothing
  4. #44
    Oct 2006
    Tifton, GA
    I dont have a panhard/track bar or swaybar on my truck and it rides AWESOME. Fix your steering box and go from there. Are your balljoints new or the same ones that came off the Blazer? Toe can be fixed by adjusting the tierod, camber will probably get better with new balljoints.
    -Daniel
    Bogger Chapter
    -Jerry Clower
  5. #45
    93 silv 4x4355 5spd
    Dec 2005
    pittsburgh pa
    their brand new balljoints thats what i dont understand.
  6. #46
    Oct 2006
    Tifton, GA
    Get a picture of how "off" your camber is. What preload did you put on the balljoints?
    -Daniel
    Bogger Chapter
    -Jerry Clower
  7. #47
    93 silv 4x4355 5spd
    Dec 2005
    pittsburgh pa
    i will as soon as i can prolly tonite or tommorow, i tightened them up man i cranked them down didnt really check specs or anything. isnt the camber adjustable under the castle nut? theres a 4 prong socket u use. but ul see in the pic its positive camber for sure.
  8. #48
    Registered User greasemonkey's Avatar
    Nov 2003
    Barrie, Ontario
    man i love the look of your truck. I had a 91 sierra that was that same charcoal colour and i miss it like crazy. hope your build works out well for you and i look forward to seeing some final pics.
    2008 GMC Sierra SLE - CCSB, 4x4, 4.8. Magnaflow exhaust. CCM 2.5" level, 285/70/17 Goodyears, 6.5" PIAA lights behind the grille, custom keyed paint
  9. #49
    93 silv 4x4355 5spd
    Dec 2005
    pittsburgh pa
    thanks man appreciate that i def got pics coming this thread is long overdue for them i just been so busy tryin to get this truck to drive haha.
    so i drove it again a little bit ago, it barely wants to turn lock to lock when im stopped, like it struggles to turn the wheels and the truck def leans so bad from side to side when i do turn the wheels. but i was wondering where do i buy that 4 prong tool for to change the camber. and is it possible my balljoints arent in good?
  10. #50
    Oct 2006
    Tifton, GA
    That four prong socket isn't to chance the camber. The only way to change camber on your axle is offset balljoints. The special socket is used to adjust the preload on the balljoints via the threaded and tapered sleeve in the top of the inner C. Once the lower balljoint is torqued to 85 ft/lbs I believe, the socket is used to torque the sleeve to 70 ft/lbs, then the upper castle nut is torqued to 60 ft/lbs IIRC.
    -Daniel
    Bogger Chapter
    -Jerry Clower
  11. #51
    93 silv 4x4355 5spd
    Dec 2005
    pittsburgh pa
    wow thats some great info man, so how do i change the balljoint angle then? hit them haha no really wats the procedure
  12. #52
    93 silv 4x4355 5spd
    Dec 2005
    pittsburgh pa
    im assume i gotta take my knuckles all back apart?
  13. #53
    Oct 2006
    Tifton, GA
    You can change camber by purchasing offset balljoints. Yes, you'll have to take everything back apart.
    -Daniel
    Bogger Chapter
    -Jerry Clower
  14. #54
    93 silv 4x4355 5spd
    Dec 2005
    pittsburgh pa
    were do i get them at ?
  15. #55
    Oct 2006
    Tifton, GA
    I'm not sure, I haven't needed them so I dont know where to get them. Sorry man.
    -Daniel
    Bogger Chapter
    -Jerry Clower
  16. #56
    Registered User nighthonda94's Avatar
    Jul 2010
    Livingston, LA
    not a 4x4 guy but i hope it work aout in a good way.
  17. #57
    93 silv 4x4355 5spd
    Dec 2005
    pittsburgh pa
    Cool Re: budget sas 93 silverado
    ok thanks anyhow im gonna take my knuckles back apart and make sure their in right, cause they shouldnt be off like this, so i think i messed something up. also my 5 inch blocks in the rear made my rear to high so now i have rake, im putting 4 inchers on end of the week, they should be here. and the new steering box goes in t nite, so well see how it goes. im slowly making progress!
  18. #58
    93 silv 4x4355 5spd
    Dec 2005
    pittsburgh pa
    so the steering box was def a problem got the new one on, it drives better, but its still a death ride truck all over the road, doenst corner or handle. and im def attributing this to my camber issue. the camber is very positve, and i cant figure out why. my alignment machine at school the old style and new style say camber is non adj on a 77dana44
  19. #59
    Oct 2006
    Tifton, GA
    I'm not sure where you get them, but before offset balljoints they made angled shims that went between the spindle and knuckle. You might be able to find some if you dig hard enough.
    -Daniel
    Bogger Chapter
    -Jerry Clower
  20. #60
    93 silv 4x4355 5spd
    Dec 2005
    pittsburgh pa
    well im stumped idont know what to do now ha and i dont know how to do my swaybar and if i should run a track bar
