Page 7 of 38 FirstFirst ... 5678917 ... LastLast
Results 121 to 140 of 750
Like Tree3Likes
my 98 gmc nightmare project
This is a discussion on my 98 gmc nightmare project within the Projects, Builds & Restorations. forums, part of the Projects and Builds category; Originally Posted by 98nightmare Yep. Ima re-cut tomorrow and start glassing it... again.. doesn't matter how many times you do ...
  1. #121
    Greg - GMC Owner 97GJMSierra's Avatar
    Jun 2009
    South Dakota
    Re: my 98 gmc nightmare project
    Quote Originally Posted by 98nightmare View Post
    doesn't matter how many times you do it, as long as its done the way you want it.
    1997 GMC Sierra 1500 SLE - Vortec 350 - 4L60E - F44
    The Only Exclusive 88-98 GM Truck Forum
  2. #122
    Registered User 98nightmare's Avatar
    Sep 2010
    South GA
    So close... yet sooo far away...lol
  3. #123
    Sep 2010
    South GA
    So i guess its to late to go back on it now...
    Some itchy time ................
    I freaken love this!!!.................
  4. #124
    Jun 2009
    South Dakota
    Wow dude, that looks amazing. I want a stepside now.
  5. #125
    Sep 2010
    South GA
    Quote Originally Posted by 97GJMSierra View Post
    Thanks, im really glad i went this way...
  6. #126
    OEM IS LAME Inverter's Avatar
    Feb 2007
    Texas
    I think having the corner tail lenses helps make that look work,,but could still look like it belongs when finished...
    I will wait for the finished product before I decide...
    What are you going to do w/the lower line on the gate? Its going to be all by itself.
  7. #127
    Sep 2010
    South GA
    Im thinking about adding some metal to the bottom of the gate -- been debating on doing a metal roll pan connected to gate, and the whole azz end hinge up to access air equipment -- dunno yet
  8. #128
    Feb 2007
    Texas
    That sounds complicated..
    Where are your tails going to be located?
  9. #129
    Sep 2010
    South GA
    in the gate.. Getting the LED strips. My handle broke inside the gate, and i dont like the handle inside the bed anyways.. I figure it may be complicated, but i think i can do a steel tube with round bar for a hinge at the top-- add a strip of steel across the top of gate to conceal it, and the bed will be fabricated inside.. Gonna put the gas tank in front and air supply in the back.. Ive thought about instead of a center cover over the bridge area, doing aluminum strips with lexan.. Like an ol school wood floor, but clear.. ( going to paint frame and suspension)
  10. #130
    Sep 2010
    South GA
    Oh yea, Troy.. Ever since you told me about the rear setup i had planned, ive been thinking of going a different rout.. A more common or basic rout at that.. Been thinking bag on axle or a KP 6 link.. Or the Extensive 2link bag on bar.. Not really fond of the 2link tho.. What are your thoughts? Its going to be a daily driver still for sure.. Wont be "hitten switches" lol.. More like aired up to town, cali in town, and lay the paint when parked..lol Im getting paranoid on which will last
  11. #131
    Feb 2007
    Texas
    My thoughts are: How much do you want to spend on rear susp.and how much lift will you need,also will you want to haul stuff?
    Tire diam./width will also affect your choices so know all that info 1st and then you can choose the setup.
    Simple is good and more affordable.
    You needd that new welder 1st. ;{}
  12. #132
    Sep 2010
    South GA
    Price- dont really matter i guess, im in no deadline so can work around things..
    Lift- clear 20x8- 5.5 backspace? with a 35 maybe 40 profile tire in front and azz sit level at that height (kinda factory or a mild static) Will be body dropped tho.
    Hauling- wont be much left of bed.. lol
    Welder- still getting a Hobart :)
    ** I hate being new to this stuff **
  13. #133
    Drive and Enjoy. Low88's Avatar
    Oct 2004
    Live Free or Die
    great job making your own shavers man. where theres a will, there's a way.
  14. #134
    Oct 2004
    Live Free or Die
    and 20x8 with 5.5" backspacing will clear but be close...
  15. #135
    Feb 2007
    Texas
    Price- dont really matter,i guess.
    Your a salesman's dream.. laugh out loud.
    6 links are expensive and you wont need all the lift.
    Steve says a 20x8 @ 5.5 will be close so you dont want to use a panhard.You can do an (offset) 3 link off the fuel tank crossmember & bag on bar(bag set into the rail). You can do a parallel 4 w/a watts link & bag over axle.You can do the KP 6 link,its the easiest route but w/the watts(must have)you will spend around $1600.for only the link kit...you will still need a notch.
    For the notch,you can buy a plate style cheap.
    If I had it to do over,I would go 3 link,bag on lower bar and set the bag into the rail w/a pocket.Its all fabrication though.If your not on a budget the 6 link kit will get it done quick cause all the math has been done for you.
    Its up to you.You will have to fab up the notch reguardless. Think about it..Theres alot of info around here and on SSM.
  16. #136
    Sep 2010
    South GA
    Quote Originally Posted by Low88 View Post
    Thank you, its an itchy experience! If i had to do another it would be the kit..lol
  17. #137
    Sep 2010
    South GA
    Quote Originally Posted by Inverter View Post
    Ive searched ALLOT and everyone has some kind of beef with every setup, but theirs naturally..lol.. Id really love a three link, but im not that sure of myself with fab work like that on a first build.. Ive noticed most of the better air mang. kits are around $1,200.+ with RE7 bags included.. And a front cup set is about $100.. and id like to stay around the three grand limit on this, so theres over a grand just for the rear setup left.. Im torn between i guess a par4 w/watts link or a tri4 both bag over axle since lift is not a great factor.. Im guessing bag on axle is a 6-8" lift range? (i hope)..
  18. #138
    Feb 2007
    Texas
    Well,,the least amount of fab would be a bolt on par4 w/ watts,also bolt on.
    You will have to weld in the notch,bridge and bag brackets but thats cake.
    Look around for bolt on par4s & watts link kits and pick out an 8 pc notch kit.
    A sleeve bag will give a nicer ride over axle(and about 8" of lift)but a convoluted Slam bag will give a little more lift.I recommend mounting them outside the rails.
  19. #139
    Ride low stay High m grasso's Avatar
    Nov 2005
    falmouth mass
    nice work man! you should make some molds with and without the body line and try and sell some kits. Id buy one. lol
    1988 chevy c1500 stepside 454 bigblock th400 Bad to the F'in Bone!
  20. #140
    Sep 2010
    South GA
    OK.. Suicidedoors.com has hardly anything i want anymore, and no fittings at all... Where is a good place to get the fittings?
