Thread: transmission fluid leak
Results 1 to 15 of 15
    Jul 2004
    i have a fluid leak from my tranny. it isn't the pan gasket(just changed that). Where else could it be coming from?
    91 silverado- automatic tranny.
    91 chevy silverado
    350 crate engine
    40 flowmaster delta flow
    Jul 2003
    Dallas, GA
    well, where is it leaking from? front, back, side, top?
    could be front or rear seal. dipstick tube. several others.
    D/D-2006 HHR 1LT 5-Speed.
    Jul 2004
    somewhere near the pan. thats how i got confused.. i thought it was the pan. so i guess you could say near the front of the transmission.
    91 chevy silverado
    350 crate engine
    Feb 2004
    pa
    get under ur truck and feal infront of ur tranny above the pan if theres fluid there its prob front seal. i have to change mine, mine leaks realy bad
    I'd rather push a chevy then drive a ford!
    IN STAINLESS WE TRUST!
    IN CHROME WE RUST!
    Aug 2001
    New Jersey
    There is also a seal for the shift linkage.
    Jul 2004
    how do i check the seal for the shift linkage?
    where is that at?
    91 chevy silverado
    350 crate engine
    Aug 2001
    New Jersey
    where is that at?
    Drivers side of trans. just above the pan. You'll see the shift linkage goin gin there.
    Ill buy that for a dollar Tahoekid's Avatar
    Sep 2003
    Minneapolis, MN
    If you can...Its best to degrease it first and get it nice and clean then run it if its a bad leak or drive it for a while. I like to at least put on 50 miles and look to see where the leak is.
    Chris.
    97 TahoeLS 4X4. Just plain stock.
    1966 Chevelle SS396, real SS w/big block 396, Muncie 4spd, buckets, console. 12 Bolt rear.
    1969 Chevelle SS396, real SS, planned 496, TH2004R, Buckets, Console, 12 bolt.
    If it aint broke, just give me a minute.
    Sep 2003
    Plano, Texas
    Mine is also leaking.....i got under and made sure the pan bolts were tight, they werent, midas was sapposed to do all that during my oil change and didnt....so now my work will be done in the driveway.
    Its probly the front seal....if its anything like mine, theres a pan looking thing infront of the fluid pan with a hole in teh bottom center, if the fluid is hangin in around there, most likely the front seal from what ive heard. thats what mine is prolly doin unless the pan bolts was what it was.
    If its the front seal, a tranny place will want 300 or more since they have to drop the tranny If you have access to someone with a tranny jack or know someone that does tranny work, go through them, cost less.
    Jul 2004
    i just remembered... the leak has been there a while. My dad and i dropped the tranny and replace the front seal not too long ago, hoping that that would take care of it. But it hasn't. Hopefully that bit of info can help.
    what else would be causing a leak now that the front seal and pan gasket is ruled out?
    thanks
    91 chevy silverado
    350 crate engine
    Aug 2001
    New Jersey
    Is it really trans fluid? Because it could be oil on the inspection cover. If your intake, valve cover or rear main is leaking....it will go down onto/into the inspection cover.
    Jul 2004
    no. it's tranny fluid. it got low one time and it started slipping a bit. i added fluid and it corrected itself.
    91 chevy silverado
    350 crate engine
    Aug 2001
    New Jersey
    OK then it's the pump seal. Also, if you overfilled it......it will leak out some 'til it gets down.
    Jul 2004
    is the pump seal the same as front seal and if not where is it at and what does changing it entail?
    91 chevy silverado
    350 crate engine
    Sep 2003
    Minneapolis, MN
    The pump seal is part of the "front pump" in the front of the transmission. Its kind of like an oil pump in an engine. when the input shaft turns the pump also does and thats what pumps fluid through the transmission.
    Unfortunately, you will have to pull the trans from the engine to change this. Same way you did the rear main. But thats typical isnt it? You go through a bunch of work to fix one thing just fine and then you have to go through it all again to do something else?
    Typical murphys law. I have the same kind of luck too.
    Chris.
