Thread: Who sells Auto Trak II transfer case fluid?
Results 1 to 20 of 26
    Hukd on Fonix Wrkd 4 Me! SilveradoZ71's Avatar
    May 2004
    League City, TX
    Anyone know where I can find the Auto Trak II transfer case fluid? I've tried two NAPA's, an O'Reilly, and several Wal-Marts. The NAPA guys knew about it but don't carry it and I didn't even bother to ask at O'Reilly or Wal-Mart.
    Also, what's the capacity?
    It's an '02 Z71 with a 5.3, 3.73's and the Auto Trak transfer case (if any of that matters).
    Thanks!
    MN
    Re: Who sells Auto Trak II transfer case fluid?
    Dealer
    May 2004
    League City, TX
    That's what I figured. :damnit:
    Thanks!
    FullSizeGMC camnut's Avatar
    Aug 2003
    Minnesota
    Have you tryed a local off road shop. One around my area sells it (just a thought) Also i think www.gmpartsdirect.com carries it?
    FSCs Author Laureate Zodiac's Avatar
    Jun 2004
    Wanderer
    Wouldn't it just be ATF?
    I run the Mobil1 Synthetic ATF in both vehicles' transmissions and both the transfer cases.
    H2 recovery team BRIDGEZ71's Avatar
    GEORGIA
    about $30 bucks a qt at the stealership
    CHEVY TECH PART TIME
    REDNECK FULL TIME
    99z-71 5.3 4.10 ...
    May 2004
    League City, TX
    Quote Originally Posted by camnut
    Not yet. The stealer is closer than the nearest off road place I found, so I'll probably end up getting it there.
    Quote Originally Posted by Zodiac
    I don't think so...not with the Auto Trak transfer cases anyway (just going by what I found on here). I tend to stick with whatever the manual says anyway. Even if it's more expensive, it's cheaper than a new transfer case and I can blame GM that way if something breaks.
    $30 a qt is pretty steep though. Anyone know how many it takes?
    Registered User jebx's Avatar
    Oct 2003
    Minnesota
    It's special stuff, it is blue in color.
    Jun 2004
    Wanderer
    Wow. That's cool.
    Today when I get to the shop I'll look it up in the computer and see if it says anything about it.
    Aug 2003
    Minnesota
    I run the Mobil1 Synthetic ATF in the transfer cases.
    Not a good idea, if you have autotrak you need to run the autotrakII fluid in the t-case. Here is the gm part #12378508
    May 2004
    League City, TX
    Thanks for the part #. It's a lot cheaper on gmpartsdirect.com...about $23 for 4 quarts it looks like.
    Any idea how many quarts it takes?
    GEORGIA
    shouldn't take more than 3 qts or so.i'll sell it....but im in ga,sorry.
    not to rub it in but i got like 3 cases of it at the house.i got auto trak also,but for some reason when i got my truck it had atf in it,and that's whats in it now.i've put 45k
    on it since.
    REDNECK FULL TIME
    99z-71 5.3 4.10 ...
    Aug 2004
    Washington, USA
    You need 2 quarts. I paid less than $6 a quart a few months ago.
    Scott
    May 2004
    League City, TX
    Cool....thanks everyone!
    Shelby, NC
    I was just quoted $6.22 a QT from my stealership.
    Shelby, NC
    Why does GM now spec auto trak II when they put dextron in from the factory? hell, my case says "dextron II or III" on it (and it is autotrac)
    May 2004
    League City, TX
    Quote Originally Posted by eng23ine
    What year is your truck? I haven't checked my fluid in awhile so I don't remember what it has from the factory. The manual says auto trak II though and I don't remember seeing anything on the case itself.
    Shelby, NC
    '99 OBS tahoe, and there is a yellow sticker on the bottom of the case, below the drain hole.
    Aug 2004
    Washington, USA
    I know the following applies to NBS trucks and I believe it should apply to OBS if the transfer cases are the same. Maybe find someone to check service bulletins for you.
    '99 and part of '00 they were putting ATF in the Autotrac transfer cases. There is a service bulletin out to replace it with the Autotrak II fluid. Generally, if you have ATF in you transfer case, you should drain and refill Autotrak II, drive it for 200-300 miles, then do the drain and refill again with Autotrak II.
    Scott
    Aug 2003
    Minnesota
    Quote Originally Posted by 2tyred
    Scott
    :word: My t-case had the ATF from the factory, i did the same thing stated above.
