Thread: Front/Rear Differential D.I.Y.
Results 1 to 18 of 18
    2007 Suburban 1500 LT jeffcolburn's Avatar
    Jun 2004
    Massillon, Ohio
    Could someone please explain to me how to change the front and rear differential fluid in my 1999 GMC Suburban 1500 4x4?
    The local shop says the see some shavings in there, and want a couple hundred dollars to fix it, but I was hoping I could do it myself to save a few bucks. Can/should I do this myself?Any info would help, THANKS!!
    Registered User jebx's Avatar
    Oct 2003
    Minnesota
    Re: Front/Rear Differential D.I.Y.
    Changing the fluid is simple, repairing the diff isn't quite so simple. What are you trying to accomplish? Your post isn't very clear; you ask how to change the fluid, but then go on to say that there are metal shavings and the shop needs to repair it. What exactly is the problem?
    This thread may provide some insight as far as changing the fluid goes. Do a search and you will find tons of info already posted. Also, get a service manual or go to the local public library and copy the pertinent pages out of their service manual or print the info off alldata dependng on what they have.
    Jun 2003
    North Dighton, MA
    There may be some fine metal in your oil, just like in your tranny oil. That isn't usually an indicator of a problem.
    How old is the truck? When was the last time the diff oil was changed? Is it the original gear set? How much abuse has the truck seen?
    Jun 2004
    Massillon, Ohio
    Actually, I do just want to replace the fluid. You're right, I wasn't that clear. The shop wanted to charge me almost $200 just to replace the fluid. I will check out that other thread.
    Jun 2004
    Massillon, Ohio
    The truck is only a '99, and I just bought it in January, so I really don't know if it has ever been changed. I don't pull anything with it, I just drive it. I don't think there is any physical damage, but I want to replace the fluid before anything doea happen.
    Jun 2003
    North Dighton, MA
    Throw some synthetic fluid in there and you'll be all set for years..
    Oct 2003
    Minnesota
    The rear is easy, just pull the cover, inspect, replace gasket (or use RTV), install, removel fill plug, fill, done.
    The front has a drain plug and a fill plug.
    Oct 2003
    Minnesota
    I'd reccomend you change the transfer case fluid too. If it's auto trak there is a special fluid for it available from GM. Otherwise, the standard manual shift takes ATF.
    Really, it probably isn't a bad idea to do them all, antifreeze, ATF, etc. Not very expensive for a little insurance.
    Registered User TSPOON's Avatar
    Jul 2004
    alabama
    I do not know if this is allowed on this site
    but i have a detailed desription on all the above
    fluid changes off another site i will post them
    if it will be ok
    someone let me know
    Jun 2004
    Massillon, Ohio
    I've seen people post links on this site before. I think everyone likes anything that helps. (thank you by the way)
    Jul 2004
    alabama
    Jun 2004
    Massillon, Ohio
    Dude, thank you for your help, those links are all I needed, THANK YOU!!
    Oct 2003
    Minnesota
    BTW, that is on a NBS truck, the OBS rear doesn't have a drain plug that the article mentions.
    Jun 2004
    Massillon, Ohio
    Then how do you drain the oil from the rear in an OBS truck?
    Jun 2003
    North Dighton, MA
    Take off the cover...
    VA
    Don't forget to scrape off the old gasket and put a new one on.
    Registered User popknot98's Avatar
    Jul 2003
    Newton, KS
    Quote Originally Posted by jeffcolburn
    umm heres your sign
    lol sorry had to be done.
    http://www.gm-trucks.com/images/Guid...front_diff.jpg is the bolt hole thats on top the fill hole for a 98 gmc z-71?? the stealership said that the filler was on the top of the other side but i aint seeing it.
    2004 Chevy Sliverado 2500HD, 285/75/16 sport king A/T, Predator, dual orig. 40's outh the corners,K&N drop-in, tint matched front and more to come.
    !FOR SALE!
    Taking offers
    New Jersey
    Resurrecting an old post .. I just had the fluids changed on my 02 Tahoe Z71. MEtal shavings -- more than what is acceptable were found in my front differential fluid. What I was told is the carrier bearings are starting to wear and need to be replaced. This is a huge job on the front diff. BEfore you just dump fluid in .. make sure the shavings/particles are within normal tolerance limits
