Thread: Watts link geometry questions....
Results 1 to 20 of 35
    03 Tahoe Physh1's Avatar
    Nov 2001
    Morgan Hill, CA
    I'm planning on making my own watts link and have gotten a good majority of it figured but I'm having a hard time finding any info about ideal geometry.
    There are lots of references to them on the net but nothing regarding setup and ideal geometry.
    Any example of what I'm looking for is...
    - Should the 2 bars be paralel at ride height?
    - At ride height should the bars be parallel to the ground?
    Any links or info anyone has would be appreciated....none of my chassis and suspension books really go into them at all.
    Cameron
    / 2003 Tahoe LT / 22" Boss 330 / Heinz 57 3"-5" drop / Pioneer / US Speedo / De-badged / E-fans / BlackBear91 / Corsa Sport / "Big 3" /
    My 03 Tahoe Build Thread
    "The power of accurate observation is frequently called cynacism
    by those who don't have it.
    " - George Bernard Shaw
    Xcentric Customs Beyond Static©'s Avatar
    Jul 2003
    baton rouge
    Re: Watts link geometry questions....
    I would assume the bars should be parallel at ride height. Just like the 4link and panhard, they are all suggested to be parallel(or level) at ride height.
    2/4 drop, GMC 20's, 4:10 gears, Blackbear Tune
    Registered User Jimmy P's Avatar
    Aug 2001
    Michigan
    good luck
    1989 Silverado Project // 2013 GMC Sierra
    ( o )( o ) 1badgmc's Avatar
    Aug 2001
    Wichita Falls, TX
    heh...Good luck. The guy who did the install on Brian's lime green truck made one and after a couple months, Brian had nothing but hell with it. Of course, I would trust your competence with this job more than I would the guy who built his.
    '91 GMC Sportside
    '98 Chevy Suburban
    '88 Chevy Crew Cab Dually
    '13 Ford Focus Titanium
    -- Jason
    Nov 2001
    Morgan Hill, CA
    Oh yeah....BTW, is there any formula or specific recommendation for how tall the center "diamond" should be? I don't forsee any issues with the planned one but it's just something I'd like to know.
    Cameron
    white and nerdy
    Apr 2002
    Dallas, Tx
    :thud: sounds like a lot of math, but i bet it would be worth it in the end. Any suspension books yall reccommend?
    15 silverado CCSB Z71
    14 Tahoe
    Aug 2001
    Michigan
    there are some good books ive read that have good articles onthem.. However there is alot of math involved to get it set up right. Main reason why i never got into building one right now.
    U ever think of getting the tp setup and then getting measuremnts for yours? You could always resell it.
    Nov 2001
    Morgan Hill, CA
    Quote Originally Posted by jimmy p
    Yeah, I've thought about it but that is just a HUGE chunk of change....dunno if I wanna swing that right now.
    Cameron
    Sep 2003
    Plano, Texas
    Alright, whats the difference in a watts link and a normal 4 link?
    Aug 2001
    Michigan
    Quote Originally Posted by Citizen Rider
    watts link just replaces the panhard bar on a parallel 4 link
    Not a preferred vendor Outlawcrewcab's Avatar
    Aug 2002
    ft worth TX
    go away 4X4 guy go build a cow catcher or sum thing i will see if my chassie bock gives me any help cam i will leyou know
    Aug 2001
    Wichita Falls, TX
    And the whole attraction to the watts link is that your axle won't shift from side to side when you raise and lower the truck.
    '91 GMC Sportside
    '98 Chevy Suburban
    -- Jason
    Aug 2002
    ft worth TX
    LOL satchell link is the correct name of a tri-4-link anyways my book tells me why to run one and to remember the load on any rear axle lateral control system can be over 2000lbs with a peak loads as high as 10,000lbs. In the photo of the watts link it showns the bars bolted at 12 and 6 at ride heigth the only other metion of the watts is to make sure to move axle full range to make sure there is e-nuff rotation
    Registered User alteredimage's Avatar
    Nov 2002
    Plainfield CT
    Total performace has a watts link for $80 and will build it for any frame width.
    Aug 2001
    Michigan
    Quote Originally Posted by alteredimage
    you mean $800?
    Sep 2003
    Plano, Texas
    Quote Originally Posted by outlawcrewcab
    :LOL::LOL:Leave me alone......troll! :bawl:
    you mean $800?
    I kinna hope he means 80. If so my trucks goin straight down to the ground.:LOL:
    Registered User low_clazz's Avatar
    Oct 2003
    michigan
    whos Total Performance? do you mean Totally Polished?
    white and nerdy
    Apr 2002
    Dallas, Tx
    Copycat:read:
    14 Tahoe
    white and nerdy
    Apr 2002
    Dallas, Tx
    Holy crap he's right, but it will only fit t-buckets or something to that effect
    http://www.tperformance.com/street_r...s_linkage_kit/
    14 Tahoe
    Know-It-All BigChevMan's Avatar
    Oct 2001
    Ohio
    Quote Originally Posted by Physh1
    Cameron
    In all honesty they are really simple. Your way overthinking the application. The center should be straight up and down on the exact centerline of the axle at ride height. It'll never leave that centerline as long as your two bars are the exact same length. The ends of the centerpiece will just tilt to either side as you go through the range of motion. The only real figuring you need to is to make sure that there is enough articulation in the bars so they don't bind across your range of motion. It's just like every other piece of racing equipment that has been modified for street use....there are comprimises. Like a 4 link, the longer your bars are the less of a change your center piece will rotate through, but since the frame is only so wide, you deal with what you have and compensate for it by allowing the center to articulate enough around it's axis.
    I hope tha you do make one. They are super nice and relatively simple.
    Never argue with idiots, they drag you down to there level, then beat you with experience
