Thread: 4x4 actuator
Results 1 to 8 of 8
    Jan 2005
    alberta
    4x4 actuator
    I have had problems with the 4x4 actuator on my 1998 SIlverado. During very cold wheather conditions, the 4x4 will not kick in. The 4wd electronic indicator light flashes x3 times then stays in 2wd. After a couple of miles, and repeated tries to lock in 4wd, the 4wd finally goes in. My mechanic has told me that the actuator needed replacing. I had the electronic one replaced for a mechanical one, but it still does it in cold weather. Anybody else have anything similar or any ideas what to do next.
    okmudslinger
    Dec 2004
    Allen,Ok.
    Re: 4x4 actuator
    I have the same trouble with my 1988 k1500 but mine will not engage at all.
    I've looked into installing a kit from 4x4 posi-lok it is a manual kit. They tell me that the system that are trucks use is a thermal actuator and they sometime don't work in the cold!!!!!!
    Feb 2004
    coastal NC
    Re: 4x4 actuator
    Cold weather shouldn't affect the 98 as all should have the later type actuator. The 88 needs the thermal one taken out and thrown as far away as possiable and then upgraded to the later type. Both of you need to check the electrical connection at the actuator. They can get salt etc. in them and corrode, reducing their performance.
    Diamond Jim
    98 Burb, 5.7L, 2500LS, 4X4; 80 GMC 383, , Long bed; 74 Dually Flatbed 350; 73 Short bed 350 4X4; 41 Chevy Master Deluxe, 327/375hp Rochester FI; 89 Fleetwood Bounder, 2 ton Chevy Chassis, 454/TH425
    Jan 2005
    alberta
    Re: 4x4 actuator
    thanks for the tips guys...
    This Bad Burb is BOOSTED! 1 BAD BURB's Avatar
    Jun 2003
    Minnetonka, MN
    Re: 4x4 actuator
    this is a common problem for the OBS trucks with 4x4...i think there was a recall on it..u might want to check that out... but yes, its a common problem...
    Aj
    1996 Burban: workhorse
    1998 C5 Vette: 9sec toy
    2007 MB E63 AMG: daily
    2005 Infiniti FX35: wifey daily
    2005 Maserati GranSport: wifey toy
    2006 Suzuki GSXR 1000: 9sec toy
    :-) Mark's Avatar
    Jun 2001
    Franklin, Texas
    Re: 4x4 actuator
    Quote Originally Posted by Diamond Jim
    GARAGE:
    03 Yukon
    02 Tahoe "HDHOE"
    09 Malibu
    00 Impala
    94 Z71
    55 Chevy Stepside
    Registered User blue99burban's Avatar
    Dec 2004
    Cranberry Twp, PA
    Re: 4x4 actuator
    i have had no problems with mine on a 99 sub
    Feb 2004
    coastal NC
    Re: 4x4 actuator
    Quote Originally Posted by blue99burban
    Isn't that precious?
    (As you can tell I am watching re-runs of SNL on cable this morning)
    Diamond Jim
