Thread: Anybody with Bagged 67-72 C10's ?
Results 1 to 20 of 28
    Rollin 17's chevy8869's Avatar
    Enumclaw Washington
    I have a 69 and might eventually bag it. It doesn't seem to difficult since I have coil springs all around. Where do you buy your mounting cups for the front and rear bags? On the rear how do they bolt up?
    Just Bump It BC Rod and Custom's Avatar
    Aug 2001
    Virginia
    Re: Anybody with Bagged 67-72 C10's ?
    I will be bagging a 70 here very soon. The parts needed are pretty simple. I'd be happy to build you copies of all the brackets I build when I do my setup.
    You just need cups and plates for the front, and a plate for the top and bottom of the trailing arm that goes where the original coil goes. The airbag mounts to these plates.
    To mod, or not to mod, there really is no question!
    Registered User slidar's Avatar
    Aug 2004
    renton,wa
    i'll be bagging mine soon, check this out http://67-72chevytrucks.com/vboard/s....php3?t=129463 .. its a complete walk through on how to do it. for suplies i would try www.suicidedoors.com .. they have all the mounting brackets for the front
    2005 GMC Sierra CCSB Z71 5.3L
    -SOLD- 2004 Silverado ECSB Z71 5.3L
    fknlow cajundragger's Avatar
    Apr 2004
    louisiana
    my bro's truck..he has air ride control arms in the front with their upper plates and he has air ride's setup for the back as well....he also has 2 inch dropped spindals and 2 inch blocks in the back...
    Aug 2004
    renton,wa
    that truck is sick
    05 GTO upgrade.
    Apr 2004
    Quote Originally Posted by slidar
    that truck is sick
    Some day I will get to finish out my 67 fleetside.
    Central coast California
    THat truck IS sick
    Apr 2004
    louisiana
    chevy8869- they have the messageboard at 67-72chevytrucks.com and you can find alot of pictures about w/e you lookin for...I know thats where my brother goes alot and I'm not sure of his username but you could find more pics of his truck on there...I know he has pics of his bag install somewheres. Its real simple and depending on how low you want to go you either run a big plate in the front under the spring perches and a cup in the lower control arms or you run cups on the top and bottom...cups on the top and bottom will make you alot lower than the plate/cup so you may not need to run 2 inch dropped spindals..but then you run into other problems the front of these truck are notorious for having..I'm sure you already know that you need to section the crossmember on it or raise the whole part of the frame that attaches to the crossmember to get it to lay flat on the rails..but again I don't know how flat and low you want to be..so if you can tell me somemore about what your looking to do I can help ya out..
    Beaner/Cracker Izzy's Avatar
    Aug 2001
    Fort Worth, TX
    Quote Originally Posted by cajundragger
    One of the nicest C10's.
    Apr 2004
    louisiana
    thanks guys...I'm going to have to show him this thread, he would enjoy seeing what yall have to say...I hope I don't get in trouble but heres a link that I found to somemore pics: http://67-72chevytrucks.com/vboard/s....php3?t=131221
    chevy8869...sry man don't mean steal ya thread or nuttin...
    Need More Parts Please!
    Dec 2003
    virginia
    Sweet truck!!
    Are the front brakes in the pic from the link factory size or larger?
    76 stepside- 5/8 drop- frame off restro
    Apr 2004
    louisiana
    I'm not sure on the size..I just know that they are bear brakes so you could prolly check out their site for specs...
    Dec 2003
    virginia
    Thanks for the info will do!
    it stinks &i dont like it 96Z-71's Avatar
    Aug 2002
    Bourne MA
    1996 GMC Sierra Z-71
    1970 c/10 2wd swb (project)
    Enumclaw Washington
    not lookin to lay all the way just have control on lifting and lowering it when I need to. I am really looking for what to do on the rear setup because my truck has coil springs in the rear and where do you get the plates or cups to mount them to the trailing arms?
    Aug 2001
    Virginia
    Quote Originally Posted by chevy8869
    You can make your own plates quite easily, but I believe that Air Lift sells the plates you need to mount a bag in place of the coil spring in the rear.
    Apr 2004
    louisiana
    yea the bottom plate is just a circle of sheet with a hole in the middle..and the top is a short cup that allows you to rub the airline out of the bag via an elboe and straight out the side of the cup. The rear cup is maybe 1 inch tall at most.
    Jan 2005
    Nashville,TN
    Go to www.earlyclassic.com. They sell a complete air bag kit for 67-72 trucks.
    paint gangsta
    Jan 2005
    Sallis,MS
    Here'smy burb as well as a C10 i painted for contrast. He is runnin bolt on kit form Airride Tech mine is all custom with dropped crossmember, raised tranny and driveline members, runnin upper plates with no lower cups on front, BIG notch, boxed trailing arms, and 2600 pound bags all the way around. Also runnin 2.5" spindles on both trucks. Mine lays frame and the pinchweld is 1/4" off ground with no bodydrop.
    http://www.krazykreationcustoms.com/
    that truck is sick
