Thread: How to fix slack in the steering?
Results 1 to 9 of 9
    Sep 2003
    Jasper,AL
    Its driving me crazy! I have replaced all the balljoints, tierod ends, pitman arm, idler arm, and steering box. What else is left? What can I do? It has gotten alot better, but still not as good as I want it. Thanks
    Nothingbutlifts.com
    Registered User bggrnchvy's Avatar
    Apr 2004
    Bay Area, CA
    Re: How to fix slack in the steering?
    Chevy's have a bit of slack in the wheel, there is no way to 100% get rid of it, you have to deal.
    1997 K1500 ECSB LQ9/80e/241/D60f/C14FF
    2006 Dodge 2500 610CTD/G56/271/AAM9.25/AAM11.5
    Sep 2003
    Jasper,AL
    mine still doesn't feel right. Any Ideas?
    Nothingbutlifts.com
    Apr 2004
    Bay Area, CA
    You replaced it all man, theres nothing left...Im right there with you. I replaced everything, still kind sucks.
    Sep 2003
    Jasper,AL
    What about making a secondary idler arm?
    Nothingbutlifts.com
    Apr 2004
    Bay Area, CA
    Did you replace the mounting place on the frame for the idler arm? Another idler arm wouldn't help, its not a mechanical deflection thing, its a power steering system thing.
    Registered User TwoTone98Z71's Avatar
    Feb 2004
    Wyoming
    steering stabilizer?
    Lift Laws Suck RICK98Z's Avatar
    Aug 2001
    Eastern Shore, Maryland
    I don't know if 96's have it but in my 98 there is a sensor located on the steering column under the dash which tells the computer to assist with steering...not sure what it is called but when taking a turn it can cause your steering wheel to jerk...I replaced it when i first did a bodylift and 33"s because it was acting up and when i did it my steering became alot tighter for awhile, now it seems loose again but nothing i can't deal with
    Rick - 04 Chevy 2500 CrewCab 4x4 - 6"Procomp Lift w/35x12.50x20 Toyo M/T's
    Jul 2002
    Boston Mass.
    dosnt someone sell a non flexing steering shaft? I was told my shaft flex's w/ larger , wide tires. cause my stearing sucks also. I tightened the worm gear on the box. and I have a steering stabilizer.
    98 gmc 3/4 ton, 6" superlift, 3" bdl,mb motoring 18" wheels, toyo 37" all terrains, 4:56 gears,bullet mufflers, roll pan, flush front bumper w/lights and a ton of other stuff.
