Thread: Radiator Drain Plug
Results 1 to 10 of 10
    Registered User Madison's Avatar
    Jan 2002
    Shreveport, LA
    Radiator Drain Plug
    Where is the radiator drain plug located on OBS Z71's, exactly?
    This Bad Burb is BOOSTED! 1 BAD BURB's Avatar
    Jun 2003
    Minnetonka, MN
    Re: Radiator Drain Plug
    it is on the way bottom of drivers side egde of radiator. u have to twist is (forgot direction) and it should just pop right off...its a lil plastic knob...
    Aj
    1996 Burban: workhorse
    1998 C5 Vette: 9sec toy
    2007 MB E63 AMG: daily
    2005 Infiniti FX35: wifey daily
    2005 Maserati GranSport: wifey toy
    2006 Suzuki GSXR 1000: 9sec toy
    Jul 2003
    New Orleans, LA
    its called a p.e.t.c.o.c.k
    1991 K5 Blazer w/ 38" SSR's
    2010 GMC Sierra Z71
    Jan 2002
    Shreveport, LA
    Hey Aj, what's the easiest way to see/get to it? Engine bay or underneath truck? Is it hard to get to? The next time I attempt the flush (Spring Break), I want to be able to find it with a blindfold on.
    Jun 2003
    Minnetonka, MN
    actually, i think the easiest way, is to just undo the lower radiator hose, ie, the hose going INTO engine... the only way i see u gettin to either of these holes, is removing the fan shrouds, upper and lower... i know when i drained mine, the fan shrouds were out, so it was wide open, tons of space...
    i don't have a stock radiator in anymore, so i cannot tell u the best way to access it..sorry bro...
    maybe some other smartarses here can chime in...ie K5Chris....LOL
    Aj
    Jul 2003
    New Orleans, LA
    i just reached down there and unscrewed it. you need me to do a tech write up?
    sorry, it's true, i am a smartass.
    2010 GMC Sierra Z71
    Jun 2003
    Minnetonka, MN
    Quote Originally Posted by K5Chris
    me-->
    me --> <--you
    Aug 2001
    New Jersey
    I agree w/ doing the hose trick too. I flushed the sytem on Ted's '99 Tahoe (4wd) when i did the intake gaskets and because of the 4wd stuff in the engine compartment it was a mofo to get to the petco(k.
    Sep 2002
    Michigan
    If you undo the pet**** the fluid runs all over the frame and it is tough to control. The hose trick is right on.
    Formerly blue_2k2_z71 Hondo's Avatar
    Mar 2003
    massachusetts
    if you can even get the petc*ck loose, they tend to break easily, i would just pull the hose off too.
    Jesse....90 GMC K1500
