Thread: cracked dash
Results 1 to 8 of 8
    Registered User paw paw's Avatar
    Dec 2004
    Crystal Springs, MS
    cracked dash
    On a '92 Chevy 1500, the dash has 3 cracks close together about an inch long at the corner of the speaker grill on the corner away from the windshield and drivers window. Any way to 'fix' this besides replacing whole dash? Any ideas?
    Registered User nawlinjoe's Avatar
    Dec 2004
    Houston,Tx
    Re: cracked dash
    I also had cracks in my dash and tried to repair them with the Permatex Dashboard repair kit but, it didn't come out too well. I purchased the dash board mat at autozone. It covers the entire dash and is custome made to fit your dash in the color of your interior.
    Registered User Grunmn's Avatar
    Oct 2003
    Anchorage, Alaska
    Re: cracked dash
    lol, fiberglass? I'm sure there are some kinds of kits though
    Grunmn
    Dec 2004
    Crystal Springs, MS
    Re: cracked dash
    has anybody ever heard of a putty fo even using a sodering iron and 'glueing' the cracks back together on the underneath dise of the dash? If this problem can't be fixed, anyone know of a reliable source to purchase a new dash? thanks
    Fear The Pinapple! Toolman's Avatar
    Feb 2002
    Hawaii
    Re: cracked dash
    Quote Originally Posted by paw paw
    I have weled plastic and there are kits available from Eastwood. Let me know if you need a link. The kits run around $300. You can weld it up but think about this. The dash is old. You will weld up those cracks and it just may crack again in a different location. If I was you and you were going to keep the truck I would change out the dash. Just my thoughts.
    Personal Responsibility GO GET SOME!
    Registered User seth350's Avatar
    May 2004
    Union City,TN
    Re: cracked dash
    check out ckresto.com
    they have just about EVERY part for older model trucks. even that dash piece, and its only $80
    *edit* my mistake....its $104.95
    04' Silverado 2500 Crew Cab
    6" Pro Comp Lift
    35" Toyo M/Ts
    18x10 Mazzi Hulks
    Jan 2004
    Ishpeming,MI
    Re: cracked dash
    Yeah I thought that dash piece was cheap and easy to change.. $100 is cheap to completely replace the top of the dash...
    1994 Chevy Silverado Extended Cab 1500 Z71 4x4, 5.7L V-8, - Restored and Better than Ever
    Dec 2004
    Crystal Springs, MS
    Re: cracked dash
    Quote Originally Posted by mike94silverado
    Obviously you have done this before? What did you use or how did you paint the dash?
