Thread: best way to weld exhaust pipe
Results 1 to 11 of 11
    Kiowa, KS
    What is the best way? We have a lincoln 215 mig welder and it will weld thin metal but I am not comfortable welding thin metal without burning the ocassional hole. I have always been told new bailing wire and a brassing tip works great. Which method is best? I do plan on using some fairly heavy gauge tubing, probably twice as thick as the stock replacement chit on there now.
    05 GTO upgrade.
    Apr 2004
    Re: best way to weld exhaust pipe
    Do this. Grab a oxy/acet torch and heat the pipe up to a cherry red in the area that you are going to weld. Doing so will clean the metal perfectly that you are about to weld. I didn't do this and let me tell you the welds look like chit but held. It took me about 2 hours to put 2 flowmaster mufflers on. I was too busy filling holes because the metal would not stick.
    Kiowa, KS
    Does that mean use the mig or the bailing wire method?
    most unique username
    Oct 2001
    Bainbridge, NY
    I think he's implying that he mig'd it. He used the torch to burn off the protective coating and oils left behind from the manufacturing process.
    I've welded regular pipe (cant remember what the guage is) with my small Hobart unit with no probs - jsut stuck pipe together and welded. Of course I was on the lowest voltage setting running small wire. If you are using thicker pipe I dont see why you'd have trouble, but you could try some practice passes on some scrap to see how the welds turn out.
    AZ Desert
    If you've never welded exhaust tube before you will blow thru the first time, I did it, I still blow thru occasionally. It's not too hard to fix a hole in the pipe, they have copper 'spoons' that will allow you to weld right over the hole, although if it's in the middle of the pipe, it will be a bitch to get too with a spoon. I used a standard wire brush to clean the pipe, no torch. Have you welded before??
    "I LIKE TO HAVE MY NIPPLES PINCHED WHEN I'M GETTING SCREWED!"
    Titties and beer bradz71's Avatar
    Dec 2003
    Dixon, IL
    Just take your time. My buddy is a great fabricator and anytime he welds thin pipe, he spot welds it. Just tack it, then run your bead around. But pause every one or two seconds to let it cool a little, then repeat. He does it and has the temp setting around 3 out of 5 and doesn't ever burn through.
    2012 3500HD
    2011 Tundra
    1979 Bronco
    1988 Samurai
    Jan 2004
    Dixon IL
    Quote Originally Posted by bradz71
    i didn't have any holes with the camaro, mainly because i took it nice and slow.
    Fear The Pinapple! Toolman's Avatar
    Feb 2002
    Hawaii
    Quote Originally Posted by vic_V8
    :word:
    Personal Responsibility GO GET SOME!
    05 GTO upgrade.
    Apr 2004
    I was welding on 8 year old pipe with over 200k on the motor. And yes I Miged it.
    Registered User popknot98's Avatar
    Jul 2003
    Newton, KS
    like said b4. tack weld it in a few places then run a 2 inch or so bead stop for about 10 seconds and give it just enough overlap to cover the end of the last weld. just take it slow and you might go to an exhaust shop and ask for some scrap pipe that you could maybe practice on...
    2004 Chevy Sliverado 2500HD, 285/75/16 sport king A/T, Predator, dual orig. 40's outh the corners,K&N drop-in, tint matched front and more to come.
    !FOR SALE!
    Taking offers
    Kiowa, KS
    Yes I have done a lot of welding in the last few years but its all been on 1/8 inch and thicker material. I've got some thin sheet metal scraps I can practice on to get the hang of things. All I was wondering is which is the prefered method to use and it sounds like mig is the way to go. Thanks for your help guys.
