Thread: Anyone do CFM.com's TBI pakage?
Results 1 to 8 of 8
    ITS CAVALRY NOT CALVARY!! Cavalry's Avatar
    Dec 2003
    horrible upstate NY
    http://www.cfm-tech.com/catalog/gm_t...5_products.htm
    they claim putting on the following things yeilds 27WHP on a stock truck, total cost $265
    CFM-Tech Tbi Power Plate #PP-100 / #PP-200
    CFM-Tech Injector Spacer #630-105
    CFM Tech Fuel Pressure Regulator #630-130* Set to 13.5- 14psi.
    Cold Air Intake Tube
    Hypertech Power Charger
    03 2500HD CCSB, 87 V3500 5.9 Cummins , 67 Bronco Sport, 66 Bronco Roadster
    Go fast w/a 2BBL???
    Nov 2002
    Illinois
    Re: Anyone do CFM.com's TBI pakage?
    I've got a similiar setup on my truck...some different componants, but basically the same deal. It helped, but I doubt it added 27HP.
    If your going to up your fuel pressure, make sure you have something to check your A/F ratio. No use dumping extra fuel in if the engine can't use it. 14 psi is a lot if you don't have a lot of mods, and a small change in psi can make a big differance in how rich/lean the engine will run.
    91 C1500 TBI 355 Ported TBI, Helix spacer, EPP Chip, 3.73's and Eaton, Hedman headers and 3" Exhaust, Vette servo Best run 15.211@87.57
    http://www.elmnet.net/~lange_c/c1500.html
    Got Jesus? Nitsud's Avatar
    Sep 2002
    Muskogee, OK
    Quote Originally Posted by Cavalry
    I also would like to know if this setup works. I more interested in getting mpg than hp.
    Nitsud
    1992 Chevy Silverado
    "Oh ya, she's a 350"
    Apr 2003
    Whitesboro, Texas
    Best thing I did for mileage was exhaust and a good ignition system. I added about 2 mpg with the Jacobs ignition I had installed and it ran much smoother too.
    Aluminim heads 202/160, cam 525/510 - 219/226 - 112 lsa, 50mm tbi, 90lb inj, 15psi fuel pressure, full roller setup, MSD ignition, magnaflow, headers, 3.73 with Eaton posi, 700R4 shift kit and 2000 stall, 255 lph fuel pump, and open air element.
    Jul 2004
    Fresno, CA
    Quote Originally Posted by 1TORUN
    Is there a specific system you got? Any links?
    2008 GMC Sierra 4.8L Ex-Cab 2WD
    24 empty tubes, BUD time! kcn6829's Avatar
    May 2005
    Amelia Island, FL
    I have cfm-tech's tbi spacer and pod spacer.
    I also have a pressure regulator and inline fuel pressure gauge (set to 13.5psi)
    MSD6a ignition with MSD wires cap and rotor
    K&N Aircharger with hypertech powercharger to raise K&N
    catco hi flo cat and flowmaster cat back 3" single out
    My net increase was from 14.5 - 15.2 mpg to 16.3 - 17.8
    all depending on the right foot, A/C and 4wd
    unfortunately aerodynamics is against us.
    hth
    ryk
    Classic's Rule 4x4K1500's Avatar
    Apr 2004
    Youngstown, OH(hr from Cle. hr from Pitt.)
    i often thot about doing these mods here to my '88 k5 it sucks gas like no other
    http://chevytruckworld.tenmagazines....aid=1324&sid=1
    Needs project money chevyz71man's Avatar
    Lino Lakes, MN
    If your worried about gas milage then why 14 psi? Thats high even for a mild built motor.
