Thread: '94 tbi 350 timing adjust
Results 1 to 19 of 19
    everything is flammable
    Jan 2005
    MD
    i had varying answers to this question...
    Can i treat the "distributor" on this motor like any other distributor...I.E. advance/retard timing at will....or does it have to be at 0degs TDC at all times.
    some say yes, some say it wont run. anyone want to clear this up?
    '94 tbi 350
    '87 Buick Turbo T.
    '94 Chevy Blazer sport 1500
    Jan 2005
    MD
    Re: '94 tbi 350 timing adjust
    nobody?
    '87 Buick Turbo T.
    shake & bake 91_bowtie's Avatar
    Jan 2002
    KCMO
    Whoever told you that it won't run if you adjust it is
    08 TBSS
    91 HD 3/4 ton
    03 Z71 Tahoe
    Jul 2003
    New Orleans, LA
    you can turn it if you want..... but it runs best at 0 degrees.
    1991 K5 Blazer w/ 38" SSR's
    2010 GMC Sierra Z71
    bye bye UTI 1992silverado's Avatar
    Aug 2004
    meridian ms
    Quote Originally Posted by K5Chris
    well everyone on here told me to advance my timing 6 degrees to make mine run better off the line so if not turning the distibutor how do you adjust it?
    Jul 2003
    New Orleans, LA
    Quote Originally Posted by 1992silverado
    i said turn the distributor if you want to...
    2010 GMC Sierra Z71
    Jul 2003
    England, UK
    where they talking about advancing the timing 6 degrees with the computer advance disconnected?
    because when u set base timing u do it with the computer advance disconnected and when u hook it back up it will be different?
    my 93 had a wire that was kinda of a light brown color and i wanna say with a black line on it,
    is under the black cover on the passager side firewall
    laters
    84 classic mini cooper, rhd, built vtec swap. qa1 coilovers, 6point roll cage, 13inch weller rims on yoko rubber
    37 chevy truck, in the works
    under the knife since 95 LOWGREEN1's Avatar
    Feb 2004
    Washington, OK
    I run my 95 (which is the same motor) at 4*. It seems that's where it likes to run the best. But like joakwin said you will have to disconnect the timing wire to set it.
    Jan 2004
    Dixon IL
    tbi motors run best with 4-6 degrees advanced.
    as stated, disconnect the wire, and set the timing, easy as pie.
    Aug 2004
    meridian ms
    so this brown or brown with black stripe wire is behind the relay panel like where the fuel pump relay is?
    Registered User SneakyZ's Avatar
    Apr 2002
    Hanover, PA
    It's right on the firewall under the plastic cover next to where your A/C lines go in. It's a brown and has a white plastic connector on it. It's the only wire in there that looks like it could be disconnected easily. Don't try to set the timing without disconnecting it first. My '88 ran best with 8 degrees, but that was with an LT1 cam. At 0 degrees, the thing was a huge turd! Once I started to bump the timing up, it really came to life.
    1968 Camaro-No motor or tranny, no floors either...
    1988 4WD longbed-TBI 350 L98 heads/LT1cam/Holley 300-66/shorty headers...gone
    96 Ext. Cab, 4WD/305/ 5spd...gone
    New truck 10/2909- '04 Sierra 1500 Z71 CCSB
    Registered User 94Chev1500's Avatar
    Apr 2004
    East Texas
    My 94's wire is under the dash on the passenger side, just underneath where the glovebox is. Again, brown with a white strip I believe. Pat
    Apr 2004
    Brunswick, Ohio
    My 94 w/ 350cid is about 7* advanced. This is where it runs best. I noticed the more mods that I did, the greater it would hesitate of the line and fall on its face. To correct this I would advance the timing 1-2 degrees till the hesitation was gone, (as long as I didnt here any knocking). This really gave me great response of the line and at the track. Hope this helps.
    94 C1500 Extended cab, 350 TBI, whipple, gibson headers, edelbrock cat back, MSD ignition, electric fans.
    Proud to be an Idiot bobzilla75's Avatar
    Nov 2003
    Lebanon, IN
    The 305 in my pops truck is running close to 10 degrees advanced. When we set it at 0 it fell on its face and couldn't get out of its own way. It's running an E-brock cam, intake and headers. Moved it by ear till she ran good and rechecked it. Right around 10 degrees is where she likes it!
    Founding member of the Indiana Chapter of the Teeny Weeny Club for Secure Adult Males
    Jan 2005
    MD
    thanks for the replies. Thats what i figured too, maybe the guys who told me its not possible thought it was a later model DIS ignition.
    '87 Buick Turbo T.
    Registered User Srabai47's Avatar
    Dec 2010
    Toledo
    i have the 1994 4.3 TBI. if you start the engine, loosen the distributor clamp then twist the distributor to the left or right. whichever makes it run smoother. find the perfect balance and your truck will run amazing. my truck used to shudder violently when it was turned off but after the timing was advanced it turned off smoothly. 2 years of thinking it was normal. when the timing was retarded, it sounded sweet with some great back fire but absolutely no power from 600-3000 RPM
    somewhere else
    It's What Lurks Within...
    May 2002
    Edmonton Alberta
    Op hasn't posted since 2008 and it was a solid 6 year thread brought up by another newb from the dead.
    Maine
    Quote Originally Posted by Badass69 View Post
    Bunch of that crap going on here today. Maybe we'll get another turbo expert soon....
