Thread: Will a 98+ 4L60E work in a older truck? (96-97)
Results 1 to 16 of 16
    Oct 2001
    Moreno Valley, Calif.
    I got a built 4L60E for sale and I have several people asking me what would need to be done to it for it to work in an older truck 96-97 year model. Also what would be needed to install say in a Camaro or Firebird? I know they make six different bolt on bell housings and tail shafts housings for it...
    Came out of a 1999 2WD Tahoe 5.7L
    http://www.fullsizechevy.com/forums/...d.php?t=148619
    Thanks for any help guys!
    Ken
    1996 K1500, Built 4340 forged 383 Engine, SRP 8.9 comp. Vortech V1-S-trim SC, 7.3L turbo diesel intercooler, BBK, Thorleys, Crower 401LM, Crower roller rockers 1.5, Custom ported big valve vortec heads, TunerCat Edit Programing, 4.10 gears, BFG 33's www.kctrading.net/sierra
    Apr 2003
    Bakersfield
    Re: Will a 98+ 4L60E work in a older truck? (96-97)
    Ken, it seems to me that if it came out of a 99 5.7 (traditional small block) then it would fit the 96-97's also. I am not positive on this as I am not a tranny guy, but if its true, then I am interested, and could pick it up next week from you as I'm under two hours away. My tranny isn't dead yet, but with 123,000 on it, and behind 400 hp I'm not sure how long it will last. If it wasn't for the aux. tranny cooler I'm sure it would be dead by now!
    97 Silverado ECSB 383, ported vortec heads, LT4 Hot Cam Kit, Vmax Spacer, 411 PCM Cal Speed Tuning, Thorley headers,Vig 2800 Converter, Duals w/ X-pipe and Magnaflows - 376.8 RWHP, 381.1 RWTQ w/ stock poppet injectors- 13.632 @ 98.94 w/ 1.90 60'
    H2 recovery team BRIDGEZ71's Avatar
    GEORGIA
    should bolt right up to another 2wd(96-99) truck.
    4wd conversion would require different tailshaft housing and ouput shaft
    camaro/similar cars probably would need bellhousing swap along with tailshaft housing and output shaft.either way it can be "reused" for several applications.
    CHEVY TECH PART TIME
    REDNECK FULL TIME
    99z-71 5.3 4.10 ...
    Aug 2001
    New Jersey
    Quote Originally Posted by BRIDGEZ71
    :word:
    :word:
    I'm not 100% sure the bellhousings are different tho.
    RIP Pop, 5th AAC WWII tdrumm's Avatar
    Mar 2003
    Northeast NJ
    Bellhousings are different from a traditional small block to a genIII.
    RIP Billy, aka budhayes 3
    Aug 2001
    New Jersey
    Quote Originally Posted by tdrumm
    True, but he does'nt mention what year F-body. It will bolt up to the LT1 correct?
    Beaner/Cracker Izzy's Avatar
    Aug 2001
    Fort Worth, TX
    I would imagine the harness could be different although I put in a 97 tranny in the wifes 98 and the stock harness worked with the new tranny.
    gasaholic/fuel addict
    Dec 2004
    Benton Arkansas
    you might want to double check but i think the valve bodies are different. I think. call your local tranny specialist. check this link trans ?
    93' 1500 rcsb 4.3 (flat tops, 30 over, cam, full roller, MSD, e fans, KnN, ram air, 4l60E w/shift kit, 3.42 locking diff. and an air freshener)
    lateral G junkie wkdspd's Avatar
    Nov 2001
    Garland, TX
    I just went through this entire setup on the current project the trans you have will work on any truck 96+. wiring is also the same. the f-body versions have different bellhousings (LS1) and different tailshafts. starters will also be different depending on bellhousing.
    Aug 2001
    New Jersey
    Quote Originally Posted by wkdspd
    What about the LT1's?
    Original Gold Member SLMDLT1's Avatar
    Nov 2001
    Gainesville, Florida
    It will bolt up to an LT1. I used my original 96 truck tranny for awhile on my lt1 before I opted to have one built up.
    2003 GMC Sierra ECSB Z71...6-7.5" Superlift, 20" Eagle 064s on 37x13.50x20 Kumho MT's, Predator, etc.
    1998 Chevrolet Camaro Z28, LS1/M6/C5's/SPEC/Lid/LT'S/MAGNAFLOW
    Aug 2001
    New Jersey
    That's what i thought.
    white and nerdy
    Apr 2002
    Dallas, Tx
    Great thread
    15 silverado CCSB Z71
    14 Tahoe
    Nov 2001
    Garland, TX
    Quote Originally Posted by SLMDLT1
    from what I understand, yes, and he confirms it - I have only played with swaps on the LS, but it makes sense since the LT motors are built off the same outer profile as the standard 350, while the LS motor is the newer profile.
    Insecure fat kid DemoN's Avatar
    Jan 2002
    San Antonio, TX
    :looking: glad i brought over that extra tranny? :LOL:
    Observationalist James B.'s Avatar
    Dec 2001
    The input shaft on this transmission is 30-spline. Gen-III and LSx engines use a version with a 33-spline input shaft. Torque converters between the two different designs are not interchangable. 4.3/5.0/5.7L Vortec and LT1 versions are all 30-spline.
    "James B." '99LT_Tahoe4Dr2WD, Tuned L29 Vortec 454, 62#Injectors, MSD6A, Six 3"mufflers, 10.5"non-float14bolt ,EatonPosi, 4.56:1, Built4L80E, Gear_Vendors, Splined_Driveshaft, HydroBoost, Be-Cool_Rad., FAL-292fans, Tracbars, Swaybars, AirRide, etc.
