Thread: A/C Low pressure valve
Results 1 to 12 of 12
    Silent but Deadly 96Yukon's Avatar
    Oct 2002
    UT
    On the low presure side hose where you fill the A/C my schrader valve is bad. This is the valve right above the A/C compressor. It has a black cap that covers it. Any one ever replaced this or know where I can get a new one? I'm assuming it unscrews like the valves on tires do. Am I right?
    Hell it's almost new again!
    New: altenator, battery, ignition, waterpump, radiator, electric fan, powersteering hose, spark plug wires, front brakes, rear axle (14 bolt SF), rear brakes, heater fan, stereo, speakers. Wait4Me PCM, 2" Body lift, K&N
    Dec 2004
    1 hour West of Chicago
    Re: A/C Low pressure valve
    yes - but you will need to evac the ac system first - unless it is empty now.
    if not the system is under pressure
    1991 Silverado RCLB 5.7, 700R4 - built, 3.42, 180F stat, March crank pulley, NGK's, MSD 8.5 wires, MSD coil, 2.0 in TBI spacer, TBI pod spacer, K&N, Homemade twin Ram Air, Magnaflow Cat, 3" 40 series Flowmaster & 3" tailpipe, 2"/3" drop, 158k miles,
    AIM = Buyer Beware
    Oct 2002
    UT
    The system is empty now because the pin won't pop out all of the way and keep the system from leaking. I didn't find this out until my A/C was low and I took off the cap to check the freon level. The cap must have been holding in the freon and leaking very slowly since I used the A/C for 2 years before it went out.
    Do you know where i can get a replacement?
    Nov 2002
    MN or IL
    Dealership I'm sure, shouldn't be too expensive for a valve...
    Dec 2004
    ant good parts store - cheap
    AIM = Buyer Beware
    Registered User 021500HD's Avatar
    Jan 2003
    Waldorf, Md
    Your local Napa store and don't forget the valve removal/installation tool too.
    Oct 2002
    UT
    Thanks guys,
    I was thinking local parts stores wouldn't carry it, mostly small branches of Autozone and Checkers, I forgot about Napa. The dealer is obviously a good choice but I didn't think about that either. I must be getting old. I'm forgeting common knoweldge stuff.
    Registered User kAdUkUbOy's Avatar
    Sep 2003
    SoCal!!!
    Quote Originally Posted by 96Yukon
    did you ever fix the problem? my '98 yukon is giving me the same prob... where did you get the valve and tool from? was it hard to replace?
    SWBLS12B long&low's Avatar
    Aug 2001
    Wichita, Kansas
    Quote Originally Posted by kAdUkUbOy
    On the 98 you are going to be better off replaceing the entire quik connect fitting. That is what I did on my 99. It is easy. They say you can replace the core but, I figured it would be safer to do the entire fitting.
    88 Ext. cab longbed TPI 350
    99 Suburban LS Vortec 350
    90 SWB Silverado 5.3l and 4l60e 4 sale will part out
    2003 Z66 Avalanche
    Jul 2004
    Nashville TN
    Quote Originally Posted by long&low
    I am having the same problem on my '99 5.7...What exactly do I need to ask for and should I go to a dealer or NAPA? Also, when replaced, does the fitting need any sealant or no? Thanks...Scott
    99 ' HOE Primetime1267's Avatar
    Sep 2004
    Sarasota
    digging up old threads... . I have to do this today also. Any input on price of the valves would be great.
    99 Chevy Tahoe White - Fabtech 7.5", Moto Metal"954" 20's with Nitto Terra Grapplers 35's, Yukon 4.56 gears
    Sep 2004
    Sarasota
    all good--I got my kit from NAPA for 10 bucks and slapped it in.. Took care of all of my leaking from the valve.
