Thread: 5.7 Vortec balancer
Results 1 to 7 of 7
    turning 10's
    Jun 2004
    Canada
    5.7 Vortec balancer
    Does anyone know if the 5.7 Vortec are internally balanced or external? I have a fluid balancer that is neutral balance and I am thinking of using it.
    A bunch of 1st gen big block Camaro's
    who me? BossHogg 77's Avatar
    Little Rock, AR
    Re: 5.7 Vortec balancer
    Pretty sure all SB's with the exception of the 400 are internal balance.
    '92 C1500 ecsb: wore out 5.7 w/Tremec TKO-500
    '69 C10 SWB stepside: 468 BB, TH400
    Jan 2003
    Roseville Michigan
    Late model 1 piece rear main seal engines are all external balanced I believe.
    Victim of A.D.D. oldredtruck's Avatar
    Jul 2004
    OKLAHOMA
    as long as we aren't talkin newer than say 1996 (cuz I wouldn't be sure on these new motors - 5.3 -6.0 etc...) she should be internally balanced- externally balanced ones- 400, 327, 283 etc... all have "notches" machined out of the harmonic balancer and
    flywheel or flexplate... you oughtta be good to go.
    1985 SWB Silverado- *one owner* (disclaimer)
    2002 F250 crew cab 7.3 PSD 4x4
    2001 Snapper 22" 6spd - mulch or bag
    2001 Echo gas edger
    1990 Stihl strait shaft string trimmer
    2008 Ferris 44 in ztr mower
    2006 Volvo V70 wagon...( Hers - but its fun as hell to drive!!!)
    turning 10's
    Jun 2004
    Canada
    It is an 98. I can always pull it off and check. Thanks
    Oct 2002
    Bright, IN
    Gen 1 small blocks with one-piece rear main seal are no longer "exactly" internally balanced as the early small blocks were. The newer (one-piece seal) engines have a weight spot welded on the flexplate to compensate for the unbalance at the REAR of the crank required for the one-piece seal.
    HOWEVER, the front of the motor and the damper are neutral balance, so yes, you CAN use the neutral balance damper.
    PCMFORLESS.COM 87 octane tune
    14.30 @ 92.2 on motor
    13.47 @ 99.2 w/ a 50 dry shot
    '96 ImpalaSS
    stock bottom LT1
    turning 10's
    Jun 2004
    Canada
    Thanks for the info.
