Thread: No PARK , TH400/3L80
Results 1 to 6 of 6
    92' 1500
    Pennsylvania
    I went to park my truck after work tonight & there basically is no park.....
    It goes into the detent , but it acts just like neutral.
    I tried adjust the linkage , but I'm about 95% sure that's not it . I adjusted it about 5 times , a cpl times the way the book said & then once a different way , just to see if it helped.
    I can't find anything technical in any books I have , but if I remember right , there's some kind of parking sprag or something like that.
    Any service techs here that can give me a hand ??
    thanks a lot !!
    92' 1500
    Pennsylvania
    parking pawl- No PARK , TH400/3L80
    I've since found an excellent diagram online, didn't print to good , but good enough I think.
    Still , If anyone has any insight into where to start looking for the problem , such as the parking pawl , or the detent area.....also is all of this accesible (easliy) after removing the pan.
    I have had a 700r4 & mopar727 apart for a shift kit install , but don't remember what it all looked like.
    thanks
    Virginia
    Re: No PARK , TH400/3L80
    Take the linkage lose from the trans and see if it goes in park if it doesnt then its in the parking pawl you can see it fron the pan but if its in the planitary gear you have to tear it down
    92' 1500
    Pennsylvania
    Can you replace the pawl if it's bad without getting "into" the trans ?
    Also , I see there's a spring involved , what's the chance that spring is broken ...
    I'm not sure how these parts all work together. I haven't opened it up yet.
    thanks
    Virginia
    Quote Originally Posted by Jwolf74
    It's a good chance but i have a good feeling its going to be in the Planetary - Rear / Output Carrier
    92' 1500
    Pennsylvania
    FIXED !!
    As it turns out , there are 2 screws that hold the whole "pawl assembly" up into the transmission.
    BOTH of those screws were loose & allowed the assembly to drop down to the point that it would no longer engage the cogged gear.
    Tightened them up , change the filter , gasket , new fluid,,,fixed
