Thread: wheel interchange
Results 1 to 17 of 17
    Dec 2005
    MS
    wheel interchange
    I have an extra set of stock '98 Z71 wheels and I sold yesterday them to a guy who has an '00 Z. He called me this morning and said the tire shop told him they would not fit his truck. I've seen '00 and up wheels on earlier body styles. Is there a reason the '98's won't work on the new body style?
    Thanks
    ----------------- Chuggs's Avatar
    Nov 2001
    Southern Virginia
    Re: wheel interchange
    The bolt pattern is the same, so I think the only issue might be that the wheels are too small. Standard on the OBS trucks were 15" diameter while the NBS are 16" if I remember correctly. So it's possible that the wheels won't fit around the brake components... But I thought even the OBS Z71 wheels were larger than the base model, so I'm not sure what the issue might be. Offset?
    ( o )( o ) 1badgmc's Avatar
    Aug 2001
    Wichita Falls, TX
    Quote Originally Posted by Chuggernaut
    OBS 4x4/Z71 wheels were 16" wheels just like the NBS. 2wd wheels were 15's. I think the problem might be with a larger diameter hub on the NBS trucks.
    '91 GMC Sportside
    '98 Chevy Suburban
    '88 Chevy Crew Cab Dually
    '13 Ford Focus Titanium
    -- Jason
    Gigity Gigity Allright badassbowtie04's Avatar
    Oct 2005
    Hebron MD
    The wheels will not fit because they will not clear the brakes in the rear. Any thing pre 99 had 15 in wheels and drum rear brakes. 99 and up have 16 in wheels(and up) and disc brakes. The 15in wheels will not clear the disc brakes.
    Aug 2001
    Wichita Falls, TX
    Quote Originally Posted by badassbowtie04
    Again, '88-'98 4wd trucks came with 16" wheels.
    '91 GMC Sportside
    '98 Chevy Suburban
    -- Jason
    St. Louis, MO
    The OBS 16" wheel won't fit on the NBS trucks due to the brake caliper.
    I sold my '01 stock 16" wheels to a guy that had a '93 4wd truck. I had planned to put his old wheels on my '01 while it was being painted, but the OBS wheel wouldn't fit over the caliper. Luckily I had my stock 17" wheels from my tahoe to use so my new Intros won't get messed up.
    2001 Silverado - Rebuild Completed KP 6-Link, ART arms, 20" Intro V-Rod Wheels, 5.3L, K&N FIPK, MagnaFlow Exhaust, Wait4Me Tune
    2005 Tahoe LT: 2/3 Belltech Drop, 20" Boyd Coddington Wheels, 5.3L, K&N FIPK, Wait4Me Tune
    Oct 2005
    Hebron MD
    Quote Originally Posted by 1badgmc
    Negative on that. My truck is a 98 z71. It came with 15 inch wheels. The same ones all z's came with and thay are 15.:nono:
    St. Louis, MO
    According to edmunds.com '98 4WD trucks came standard with 16" wheels.
    http://www.edmunds.com/used/1998/che.....5.Chevrolet*
    http://www.edmunds.com/used/1993/che.....5.Chevrolet*
    FSC's Resident Banker 02Z's Avatar
    Statesboro, GA
    Your wheels aren't stock then...or you have a base truck with Z71 stickers on it. Look it up..talk with any dealer..they all had 16" wheels on them. Now if you have a 2wd you have the 15's.
    Sig courtesy of: ilikedirt
    2002 Chevrolet Z71 ECSB LT, 305/70-16 Toyo Open Country AT2's, 3" BL, Flex-a-lite 292 E-Fans
    Captain Cement Shoe 99SLT's Avatar
    Sep 2002
    Mass
    I just had this same problem over thanksgiving. My buddy has a 2001 Tahoe with 23's ( I have an obs 99 Yukon). He needed a front end alignment but the alignment shop couldn't do such a big wheel. I gave him a set of stock wheels (16 inch)off my truck but the rears would not clear the rear calipers on his truck. I had to meet him down at the shop with my truck, take off my escalade wheels and send him off to get his alignment done. I thought they were all the same but I guess not
    Aug 2001
    Wichita Falls, TX
    Quote Originally Posted by 02Z
    Exactly. Every single 4wd '88-'98 truck or SUV that I can remember with stock wheels had 16's. Even base models had 16" steel wheels.
    '91 GMC Sportside
    '98 Chevy Suburban
    -- Jason
    Woodstock Ontario Canada
    eery 88-99 OBS truck that was 4wd had 16" rims, 2wd had 15".
    peace
    Pauly
    - Luke 1989K1500's Avatar
    Jan 2005
    Ravenna, Michigan
    Yours are not stock then.
    Nope. 16. Trust us. :read:
    88-98- 2wd came with 15 inch, 4wd came with 16 inch.
    Nov 2001
    Southern Virginia
    1/2 credit to me for being close :assclown:
    Registered User josh89chevy's Avatar
    Aug 2004
    CT
    every 88-99 OBS truck that was 4wd had 16" rims, 2wd had 15".
    Correct.
    Jun 2003
    Murphy TX
    Quote Originally Posted by rsz71
    Thanks
    To answer your question, No they wont the brake hardware is too large.
    Newer wheels will fit older but not the other way around.
    projects One Ton Jeep & 4x4 Crewcab 3500HD
    "That'll buff right out."
    Apr 2005
    Boston, MA
    the ouside diameter must be the same between OBS 16's and NBS 16's. the inside diameter must be smaller on the OBS 16's, which im sure most of us gathered from this debate lol.
    2000 Silverado Z71 5.3
    1994 Blazer 5.7 TBI
