Thread: cv axles break repeadetly
Results 1 to 18 of 18
    Registered User jimbo92's Avatar
    Greenwood, SC
    guys i dont know what the problem is i have blown 5 cv axles in two months 4 in the last 2 weeks 4 of them have been on the passenger side, 1 broke in the mud, one broke climbing a hill not hard just very light throttle, and snap, hte next broke in 2wd while going around a gate at the farm, the next broke when flexed ina ditch going into the field, the next broke while pulling into parking space, only the last one has been the driver side, the torsion bars are not turned much, the rear susp is stock and it is still slightly lower than level, has anyone ever had this many problems with these peices of junk, my ttb 84 bronco has taken countless abuse hopping up and down on packed dirt in 2nd gear 4lo and been rockcrawling numerous times and not given the slighest hint of a week spot, so what is this things deal?
    buildup in progress bretsk2500's Avatar
    Sep 2005
    Sanford, Maine
    Re: cv axles break repeadetly
    where are you getting your replacements? I've never had a problem with mine.. even buried the truck to the frame a few times.
    02 K1500 Z71 Avalanche bone stock
    88 K2500 350 TBI, 10" Edelbrock OE, Ultimate TBI, Summit 1102 cam, MSD 8.5mm wires, built 700-r4, BFG AT/ko's, 3.73's, Flowtech Afterburner Headers, Magnaflow 3" cat, Flowmaster Super 40.
    To be ordered: Holley 300-66 intake
    Greenwood, SC
    well the first blown was replaced with junkyard special on the pass side when it broke i got an advance autoparts shaft, the two after were also because of warrenty, the 5th one to break was still the factory unit, it broke pulling in a parking spot, you would think it would have broke when i played tug-o-war with an f150 earlier that day or when i went and pulled a guy out, but nope it randomly broke on pavement in 2wd
    Registered User Arctic_Scrap's Avatar
    Apr 2003
    Duluth, MN
    They aren't randomly breaking. It sounds like you beat the chit out of them and they aren't made for that. Usually once they go bad it takes a few miles on them to really start making noise. I had to replace both in my old truck that had 35's because I got stuck with it. It took one shaft about a week to go bad and the other about a month.
    2009 Chev 2500HD
    1997 Jeep Wrangler, 5.3/4l60e. Locked up 1 tons on 42s.
    1946 ford coupe, chev 327/th350. Chopped and dropped.
    Greenwood, SC
    no im not beating the **** outta them, the only time i have ever done anything hard to the truck was when i hooked up to the ford, other than that when i went to pull the guy out when i got there he was out and i kept my truck in 2wd, the first axle the boot was ripped so i assume dirt and contaniments ate out all the grease, but after that the next three were totally unacceptable, driving up a grass hill in 4 hi not even spinning the tires, going through a grass ditch to go into a field, the ditch wasnt even deep enough to lift a tire, and one broke in 2wd going around a gate in gravel and the other broke pulling into pizza hut last night, so no its not from beating the **** outta my truck, the truck is babied with the expception of hooking to the ford, the bronco is for beating the **** out of because apparently it takes it better than the chevy
    Greenwood, SC
    the first shaft rattled for about 15 min and then broke all the others have been totally spontaneous snapping
    Apr 2003
    Duluth, MN
    Is the truck lifted?
    2009 Chev 2500HD
    - Luke 1989K1500's Avatar
    Jan 2005
    Ravenna, Michigan
    Quote Originally Posted by jimbo92
    I'm guessin the bronco is sfa, thats the reason you dont break as much **** in that.
    s10er8
    people get offended when they hear the truth so dont take it the wrong way ifs guys
    those cv joints don't hold up to much stress at all like you said man but somebody should make a heavy duty cv for it that you wouldnt be able to break but then the shafts themselves would start breaking or you would be breaking the hubs or maybe even the carrier. or it could be worse and you start breaking driveshafts or gears
    basically when you start beefing stuff up there will be a weak link until you upgrade everything...the cv is kinda sacrificial to save the other parts from damage, almost like a fuse blowing to protect a circuit
    like I said earlier you should be able to upgrade to better cv joints though
    young and stupid er1c43's Avatar
    the heart of DIXIE [*><*]
    i say turn the torsion down for a while and see if it still breaks with it down close 2 stock
    lD
    Last night my girlfriend came home earlier than she ever has and caught me, naked, watching porn, and stroking it with a mask and snorkel on.
    3" body lift,G-gaydee 35s, 3" straights dumped, cobra 29LTD cb w/ 102" whip
    Registered User shackwrrr's Avatar
    south eastern ohio
    im thining that maybe you front end is locked in and wont unlock i had that happen to me when i was in deep mud i could be your cable that acuates the front axle im thinking this becuse its breaking in 2wd and its getting worn out like having it in 4hi on dry pavement check your vacume auator under your battery and see if its engaged if so see if you can get it un stuck or pull the vaccum line and see if it disengages if so you need a new vac switch on your xfer case
    1990 s10 blazer 4x4 262 no mods yet but has proven itself in mud in 4x2
    1998 s10 262 scsb needs a tranny hope to have runnin soon
    if you like 4x4 trucks come on over to my forum i made just for chevy 4x4s http://s2.phpbbforfree.com/forums/in...forum=chevy4x4
    Quote Originally Posted by shackwrrr
    if it is the lever 4wd like mine or lock in after u engage it ur supposed (or its good 2) roll back about 15-20 ft to make sure its unengaged, could this be a problem 2?
    lD
    Greenwood, SC
    im pretty sure its disengaging bc when u put it in two and dont back up it still acts like its in 4, but if u do back up it wont do it, the ol bronco is the ford famous Twin Traction beam, talk about a hard vehicle to align, but its basically the same principle as a solid so i guess thats why its strong, does anyone make a manual hub conversion for this truck, i had a 2000 tacoma with the manual hubs and loved them, heck if this think keeps blowin cv's that solid hp 44 i had in store for the bronc may find a home under this thing
    BAD ASS HD
    Sep 2002
    Northwest, AL
    How steep are your cv angles.
    Mac
    '02 2500 HD, 6.0, 50 Series Flowmaster, Custom built bumper, Camo Edition.
    Greenwood, SC
    not too bad they still droop when i jack it off the ground, its only turned level with the stock rear no blocks, actually its a little below level, i have a buddy with an identical truck with 2 inch blocks and maxed bars and he has had 0 problems
    Registered User josh89chevy's Avatar
    Aug 2004
    CT
    Quote Originally Posted by s10er8
    I agree 100%. Although, I don't think they should be breaking that much, there's something else wrong here.
    s10er8
    Are the replacements you get rebuilt or new? That could be the problem
    Trucks are like women...
    Dec 2005
    KS
    Try looking into some reinforced heavy duty cv shafts. Also make sure nothing is tearing into the boots themselves.
    Indigo Blue 2002 Silverado "Blueballs"
