Thread: How to tell what size ring gear you have???
Results 1 to 7 of 7
    Registered User 9296GTs's Avatar
    Sep 2005
    Fayetteville, NC
    Is there a way, besides pulling the pumpkin cover off, to tell what size ring gear you have.
    My rear dif sill is leaking and when i checked into getting a new they said my truck came with 2 different rear ends, 10 bolt or 12 bolt.
    Truck is a 97 (chevy) Z71
    Registered User popknot98's Avatar
    Jul 2003
    Newton, KS
    Re: How to tell what size ring gear you have???
    pull the rear wheels off the ground, make a mark on the bottom of the u joint and the bottom of the tire. spin the wheel till the mark on the tire goes around once and cout how many times you d-shaft rotates.
    either that or just look in the glove box if you know they are stock.
    cout the bolts on the diff cover and thats 10/12 bolt
    2004 Chevy Sliverado 2500HD, 285/75/16 sport king A/T, Predator, dual orig. 40's outh the corners,K&N drop-in, tint matched front and more to come.
    !FOR SALE!
    Taking offers
    Mar 2003
    high falls,ga.
    are you talking axle ratio or the actual ring gear size?if your truck is a 1500 you either have the 10 bolt 8.5 ring gear 30 spline 6-lug(most likely)or a 14 bolt 9.5"ring gear 33 spline 6 lug axle.you could not get a 12 bolt axle on that year truck.
    Sep 2005
    Fayetteville, NC
    Yeah, I am talking about the diameter of the ring gear. The diff front seal is leaking and Advanced Auto told me that there are 2 different seals, one being for a 10 bolt and the other a 12 bolt.
    I was told that you can't count the # of bolts on the diff cover, because there might be a 12 bolt ring inside the 10 bolt case. I do not know if this is even possible.
    I really love my truck, but am a Ford guy, so I am not real Clear on GM rearends. I know the 8.8 and 9" very well.
    Was just trying to keep from having to pull the Diff cover off and counting ring gear bolts.
    buildup in progress bretsk2500's Avatar
    Sep 2005
    Sanford, Maine
    Quote Originally Posted by 9296GTs
    the 12 bolt hasn't been used since 1982. you've either got a 8.5" 10 bolt or a 9.5" 14 bolt... there's no way you're going to get the wrong ring gear in there.. just plain won't work.
    02 K1500 Z71 Avalanche bone stock
    88 K2500 350 TBI, 10" Edelbrock OE, Ultimate TBI, Summit 1102 cam, MSD 8.5mm wires, built 700-r4, BFG AT/ko's, 3.73's, Flowtech Afterburner Headers, Magnaflow 3" cat, Flowmaster Super 40:rocking:.
    To be ordered: Holley 300-66 intake
    strait_thug chevalade's Avatar
    NC
    To answer the question you need answered--look at the differential cover of the rearend. Count the number of bolts holding that cover on--if there's 10, you have a 10 bolt, if there's 14, it's a 14 bolt. Also--if you have 8 lug wheels, you are 14 bolt!!
    Sep 2005
    Fayetteville, NC
    Hey thanks, that's what i needed to know.
