Thread: Heated seat not working on Tahoe
Results 1 to 13 of 13
    May 2005
    MN
    I just bought a '98 Tahoe LT and the drivers side heated seat is not working. The other side works just fine. I don't see a fuse for this.
    Any suggestions on where to start with this?
    Thanks,
    Jon
    Jul 2004
    Canada
    Re: Heated seat not working on Tahoe
    check for power at the switch.
    if yes
    check power after the switch is turned on
    if theres power there, then check at the element... if theres power there then you have a bad element and you need a new one.
    if there is no power after the switch they you have a bad switch.
    if there is no power at the switch, get a schematic to find where the power comes from... check for power there... run a new wire if need be.
    Best quesses in order..
    fuse(theres going to be one somewhere... Im going to check my 98 tahoe for one tomorrow)
    switch
    elelment
    wiring
    Captain Cement Shoe 99SLT's Avatar
    Sep 2002
    Mass
    I had the same thing happen to me in my Yukon. Luckily it was still under warrenty, although it was a battle to get fixed. The heating elements were toast, they were covered under the warrenty. But they are sewn into the leather which is not under warrenty. I had to fight to get my seat redone to get the heated seat to work. Why would GM say they cover a part just to say it's not covered because it's attached to something else.
    May 2005
    MN
    Thanks, I'll check those things out and post back.
    May 2005
    MN
    Someone told me the heated seats don't work unless there is someone sitting in it, is this true?
    If so, I may have to sit in the seat to diagnose the problem?
    Thanks.
    '98 Tahoe LT
    Sep 2002
    Mass
    you need to have the seatbelts locked in to get the heated seat to work
    duramax 99SKALAID's Avatar
    SF bay area
    Quote Originally Posted by 99SLT
    In my 1999 escalade it has front and rear heated seats.
    The driver seat heater does NOT need the seatbelt connected to work.
    All the other three DO require the seat belt to be buckled to complete the circuit in order to make the seats heat up.
    Dec 2005
    wa
    left front, no seatbelt needed...99% odds you have a bad element.
    (chev service writer) the fuse operates both, so if one works, it's not a fuse.
    May 2005
    MN
    Thanks for the help. I haven't had a chance to check it out yet (Minnesota winter).
    So, worst case its the element...is this hard to replace, and what might me involved the repair?
    Jon
    '98 Tahoe LT
    SF bay area
    Quote Originally Posted by HaywardBound
    Jon
    all new leather cushion
    May 2005
    MN
    Sounds too expensive right now. I'll put it on my list, first new stereo, then auto start, then new seats...
    (At least my kids are happy with their ipods and stuff)! (My stuff will have to wait)
    '98 Tahoe LT
    Jul 2004
    Canada
    I priced out a cover+element at 860buxx...
    Jan 2010
    middletown, DE
    I have an 03 Tahoe, first, driver seat up and down control have switched direction, then heated seat turns off immediately, now passenger window not working....is there a module in the driver panel that may have gone bad? Trying not to do the dealer thing....anyone have any luck or info?
