Thread: How many amps does two H3 100watt bulbs pull?
Results 1 to 5 of 5
    Registered User go-dwr's Avatar
    Dec 2005
    Ohio
    I want to put these in the fog lights on my truck and right now I have 55 watt with 15 amp inline fuse from the battery, so would this setup be ok for two H3 halogen 100 watt bulbs replacing the 55 watt ones or do I need a 30 amp inline fuse?
    Lompoc, CA
    Re: How many amps does two H3 100watt bulbs pull?
    Quote Originally Posted by go-dwr
    200 watts at 12 volts would be 17 amps. I thing you want to upgrade the fuse AND the wiring.
    Amps = Watts/Volts
    KJ6LFD
    Dec 2005
    Ohio
    Thanks I will get the bigger fuse and wiring and I already have it hooked to a 30 amp relay with seperate wires for each light with 14ga or 16ga wire but the relay is powered from 15amp inline fuse that I will upgrade to 30amp inline. Is the 14ga or 16ga seperate wires to the lights ok or should it be a 12ga wire to each light?
    Lompoc, CA
    Here is a link to a wire size / length / amps table for 12 volt systems:
    http://www.msinter.net/tradingcave/windpower/wiring.htm
    Too small a wire can overheat and melt the insulation.
    A longer wire causes more voltage drop than a shorter wire; less volts means less light output. Compensate by using a larger diameter wire.
    The only problems with too big a wire is cost and it's harder to run around the vehicle.
    Be sure the wire is well supported away from exhaust and doesn't rub against anything. If it goes through a hole, use a grommet.
    If something goes wrong and your truck burns, don't come out here to kick my a$$.
    KJ6LFD
    Feb 2004
    coastal NC
    Amps X Volts = Watts
    Watts / Amps = Volts
    Watts / Volts = Amps
    Q.E.D.
    Diamond Jim
    98 Burb, 5.7L, 2500LS, 4X4; 80 GMC 383, , Long bed; 74 Dually Flatbed 350; 73 Short bed 350 4X4; 41 Chevy Master Deluxe, 327/375hp Rochester FI; 89 Fleetwood Bounder, 2 ton Chevy Chassis, 454/TH425
