Thread: 4x4 question after front axle half replacement
Results 1 to 6 of 6
    Dec 2005
    NJ
    90 gmc k1500 Sierra 4x4. Replaced the passenger side axle half (cv axle) and now 4x4 does not work. When I pull to 4Hi it does notyhing. When I put the truck in neutral to got to 4Lo I get a clunck as if its in 4 but nothing. Now when I take it out of 4Lo it grinds.
    After further review of install I noticed the axle half that was replaced seems to be pulling the piece that mounts into the front differential out about 1.5 inches. Why is that?
    Is that the reason 4x4 does not work? did something else happen when the axle half busted . It busted while in 4x4 on snow.
    Need this truck back for work.
    DBG
    Sep 2005
    San Luis Obispo, CA
    Re: 4x4 question after front axle half replacement
    The flange coming out of the front end shouldn't pull in and out. If that shaft broke inside of the front end, the ring and pinion might be spinning inside, but the good side won't spin because it is not locked up. Check to see if your front drive shaft is turning when its in 4x4. If it does turn and the front end looks good, it might be a bad actuator.
    Darren
    89 RCSB Dana 60/14 Bolt 4-lnk frnt/rr, 39.5's/14" Welds, 5.13, Truetrac/Detroit, AEM Intake, Holley 670 TBI, Holley Mnfld, Shorties, 40 series, no cat. 98 2wd 355, lt4 hotcam, 1.6 rllr rckrs
    Project Pics:
    http://community.webshots.com/album/366426764ygYniE
    Nov 2004
    Old Mission, Mi
    Quote Originally Posted by killiannj
    If the shaft was pulled out of the extension housing on the passenger side and just shoved back in, that is your problem. There is a thrust washer down by the disconnect that will fall down and not allow the shaft to be inserted all the way. The washer will also block the operation of the CAD. You have to remove the extension housing on the passenger side when removing/reinstalling that shaft so that you can install the thrust washer properly. If you did not pull the shaft out, it may have just pulled out when the CV shaft broke.
    Dec 2005
    NJ
    Quote Originally Posted by Black Dog
    So pull the CV Shaft again. PUll the extention . Also pull the whole housing for the extention?
    ONce inside what am I looking For to make them line up?
    Nov 2004
    Old Mission, Mi
    It is a very simple design. Once you pull off the extension housing/stub shaft, you will see the thrust washer in there and it will be obvious where it goes.
    Dec 2005
    NJ
    thanks, I'll get to it later this weekend and get back to the page with results.
