Thread: How do I remove the 4L60E in my 4x4 Tahoe?
Results 1 to 7 of 7
    has no car payment! TIMSPEED's Avatar
    Jan 2003
    Modesto, CA
    Does this sound right?
    1.) Unbolt both front & rear driveshafts from Transfer case
    2.) Unbolt transfer case from transmission (6 bolts right?)
    3.) Remove transfer case from vehicle
    4.) Unbolt transmission from engine (6 bolts, right?)
    5.) Unbolt transmission from crossmember
    6.) Slide transmission out
    Just worried about those torsion bars/crossmember...will it be in my way really?
    -87 Corvette Z52 Coupe
    *K&N Filter,Yank Torque Converter,Custom Cat-Back
    -95 Tahoe 2-door 4x4
    *Posi-Lok/G80, 285's, Custom Cat-Back, 3.73's
    -96 S10 ECSB V6
    *ZQ8 Rims, 3" BellTech Drop, Dynomax Cat-Back
    Registered User 6.0 Silverado's Avatar
    CA
    Re: How do I remove the 4L60E in my 4x4 Tahoe?
    Quote Originally Posted by TIMSPEED
    first thing you wanna do is get some type of support under the tranny
    I beleive that the cross member is bolted the x-case and there are only 4 bolts between tranny and x-case(atleast that is the way it is on my truck)
    make sure you get all linkage and wires disconnected from tranny and x-case
    This is probably going to be messy btw
    The first thing I did was put a jack under the tranny to take the weight off and then pulled the cross member. then x-case. then tranny. thats what I did atleast.
    I hope this helps
    Jan 2003
    Modesto, CA
    I'll be using a nice tranny jack, so no worries there.
    -96 S10 ECSB V6
    Brandon, MS
    Should the engine be supported in any way while or once the tranny is out?
    Didn't know if it may rock forward or back.
    98 Yukon SLT 4X4
    5.7L/4L60E/NP246/3.73/open
    K&N/285-75-16 F-stone Destination MT
    86 Blazer 4X4
    305/4bbl/700r4/NP208/3.08/G80
    31x10.50x15 Sport King AT
    Registered User RyanC350's Avatar
    wilson nc
    nah you dont have to support the engine any
    AL
    how much does the 4l60e weigh?
    Apr 2005
    Long Island NY
    Quote Originally Posted by Atomic
    According to GM Powertrain, they weight in at 163lbs. I assume this is with the converter
