Thread: LED bulb replacement and hyper flashing - a DIY solution
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 93
    Registered User 01 Suburban LS's Avatar
    Sep 2003
    San Jose, CA
    I did a quick search to see if this info was posted before, nothing came up so here I go:
    I recently replaced all the bulbs in my 2001 Suburban with LED replacements from hid-lights.com. Specifically the ones that I'll post a pic to below. Anyway, I figured I'd have a problem with hyper flashing. After a little searching on-line a DIY solution was found.
    Inside our flasher is a chip. It is a U643B Automotive Flasher chip. It basically controls the relay that turns the lights on and off. This chip has circuitry that can detect when a light is out by looking for a reduction in load (current). The chip will see this and trigger the lights on and off twice as fast to alert the driver that a bulb is out. From what I can find out by researching the flashers part number, 1999-2002's use the same flasher as my 2001. But I have owned other GM vehicles with a different flasher modules that this same mod works on. If you open up the flasher module and the U643B chip is present, this mod should work for you.
    Luckilly this is all done with one pin on the chip. What you need to do is take the stock electronic flasher apart and cut the leg of the chip on pin 7 coming off the chip. You will loose the 'lamp failure detection' on the chip. But the lights will flash normally. And you saved some money as long as you don't break the flasher.
    Click the link below for more information on the U643B chip.
    http://www.atmel.com/dyn/resources/p...ts/doc4727.pdf
    Here's my DRL's replaced with LED bulbs.
    2001 Suburban LS.
    18x10 Eagle 064's, 6" ProComp lift, Ford Keys, 1.5" rear coil spacers, 35x12.5x18 ProComp X-Terrains
    http://www.cardomain.com/ride/2175737
    SPL NUT!!! idbl_Fanatic's Avatar
    Jul 2002
    Stockton, Ca
    Re: LED bulb replacement and hyper flashing - a DIY solution
    Can you post a pic of the inside of the flasher? so that people will know what "leg" to cut?
    Need more power? UP YOURS!! with Excessive Amperage!
    Sep 2003
    San Jose, CA
    I'll will when I do the one on my parents Tahoe. But if you download the PDF from the link above you'll see a drawing of the chip. Its very self explanitory.
    2001 Suburban LS.
    most unique username
    Oct 2001
    Bainbridge, NY
    Nice find! Thats good info - sometimes its hard to find detailed tech info on chips/modules used in the automotive world.
    So you've actually done this and things work fine? Just curious because after reviewing the info I was thinking that without proper input to pin 7, the comparator (K1) would go high, driving the pulse generator into double rate mode (just as if a bulb was out).
    Sep 2002
    Michigan
    Can you tell if it is possible to access the resistor which controls the threshold of voltage that determines a bulb is out? If you replaced the 30 milliohm resistor with a different resistor, could you change the voltage at which the circuit thinks a bulb is out? (I just don't know where they come up with that 81 mV reference voltage.)
    Sep 2003
    San Jose, CA
    Quote Originally Posted by ibthumpin
    Yeah it works great. It may blink slightly faster than normal, but barely. Its definatly not flashing double time.
    I have some video taken with my cell phone. Unfortunatly you need the latest version of Quicktime to view the type of files my phone records. I'll post them below.
    http://www.differentracing.com/mike/...0Flash%201.3g2
    http://www.differentracing.com/mike/...0Flash%202.3g2
    http://www.differentracing.com/mike/...0Flash%203.3g2
    http://www.differentracing.com/mike/...0Flash%204.3g2
    Quote Originally Posted by MIZ71
    I'll have to check, I honestly dont remember seeing it. But then again, I wasn't looking for anything but the chip.
    2001 Suburban LS.
    Sep 2003
    San Jose, CA
    As promised.
    Here is the high resolution image (1.9megs):
    http://www.differentracing.com/mike/...flasher-hi.jpg
    And the low resolution image (65k):
    http://www.differentracing.com/mike/...flasher-lo.jpg
    I labeled the pins on the chip. We just desoldered the leg of the chip, but if you have some fine tipped wire cutters, that should work too.
    2001 Suburban LS.
    Kick Ass!! Red94Chev's Avatar
    Sep 2005
    Edmonton, AB
    Are they quite a bit brighter than stock?
    Sep 2003
    San Jose, CA
    Quote Originally Posted by Red94Chev
    They're about the same. Up front with clear corners the color is more intense. The instant on and off when flashing is pretty cool looking too. Orginally I was only going to do the DRL's since they always seem to burn out and the plastic socket was all burnt up.
    Incadescent Bulb:
    LED Bulb:
    2001 Suburban LS.
    Sep 2003
    San Jose, CA
    We also installed the same bulbs in my brothers Saturn SL2. Heres pics of his.
    Brake Lights:
    Turn Signal:
    Backup Lamp:
    2001 Suburban LS.
    Lost before Dawn CustomChevyGuy's Avatar
    Aug 2004
    305, South Fla
    i realize this is an old thread, but would the same information apply to my 03 silverado? and if it does, where do i find the GM Combination flasher? up under the dash, or is it in the engine bay??
    thanks..
    Quote Originally Posted by bhookxen
    sometimes bad-assery takes time
    71 Chevelle 454
    03 rcsb, 06 clip/tails, HD hood, Esky handles, Alpine head unit, 5% tint, clear corners, 8K HID's, FM50, 2" rear drop, debadged, BlackBear Tuned!
    Registered User The Performer's Avatar
    Oct 2008
    This is a good thread!
    I bet its in the under the hood fuse block. And I bet we have them in our 03's as well.
    Click to see my build!
    Proud DC owner!!!!
    S/C Z71
    Do it right and get the proper flasher.
    allergic to mud RollingBowTie01's Avatar
    North Bay, CA.
    where is the flasher located under the dash?? i popped my head down there and came up with nothing.
    sig by 454ss
    01 silverado/4.8 jet chip/K&N 77 series/throttle body spacer/3/4 belltech drop/20x9.5 boyds wrapped in 295/45/20 Toyos/'05 tails/leds/and more to come.
    S/C Z71
    Turn your flasher on and follow the ticking sound.
    North Bay, CA.
    i just went to the parts store and picked up an LED flasher. worked out way better then cutting anything.
    sig by 454ss
    Sep 2003
    San Jose, CA
    Quote Originally Posted by RollingBowTie01
    Except for the fact you did half the work by simply removing the old one and installing the new one.
    2001 Suburban LS.
    North Bay, CA.
    oh yea... damn the hard work that was pullin out the old one and pushin in a new one.. whew....
    sig by 454ss
    AL
    Where did you get a new one? Only ones I could find were $100+
    I got the $10 resistors from vleds instead.
    Sep 2003
    San Jose, CA
    You missed my point. In the time it took you to stand in line to pay for that flasher. You can have done to the flasher you already have exactly what some Chinese kid being paid $0.10 a week did to the one you bought.
    Looking at your sig picture of your truck, I assume you did most if not all of that stuff yourself. Moding the flasher ranks up there in difficulty with swapping in those clear corner housings.
    2001 Suburban LS.
