Thread: 1995 chevy z71/k1500 manual transmission noise
Results 1 to 10 of 10
    Mar 2006
    california
    I have a 1995 z71/k1500 with a 5.7l, and 5 speed granny transmission, recently replaced the clutch pack and upon start up noticed a whine when in gear or in neutral, the noise goes away when i engage the clutch, have checked the linkage, checked the clutch slave, checked the transfer case, redropped the tranny, everything checks out ok, but noise is still there... only thing i can't rule out is the fluid.... i got the fluid specs at autozone..
    GL5 80w90 is what i was told to use... but now the dealer says syntorque fluid...can the difference between synthetic and regular oil make the difference in noise? anyone had this problem? i'm gettin po'd with my truck.
    Registered User JayBer's Avatar
    Thibodaux, LA
    Re: 1995 chevy z71/k1500 manual transmission noise
    Whoa AZ was wayyy off there bud... you need to use Synchromesh fluid... not only is it Synthetic, its a lot thinner... you will wear your synchros with 80-90..
    or another, you can use a Synthetic 5-30 motor oil...
    Jay Bernard, Thibodaux, LA
    2005 GMC Sierra crewcab, 5.3, LS1 hot cam, z06 springs, 93 tune by thunder racing, Trailblazer converter, 3:42's, G80, 4-6 drop, Joe gibbs wheels
    1962 Chevy Longbed fleetside, 235 straight 6 dual rochester carbs, split header, glasspacks and :fire:flamethrowers!
    Mar 2006
    california
    unfortunately it was a sunday, and i had to get the truck back together asap.
    figures, az has gone down in the past few years... i'll swap my fluid out. just wondering if the standard oil was making it whine like it was trying to go in gear.
    Mar 2010
    Lyford, IN
    Did you figure this out? My 88 is doing the exact same thing.
    97 Bowtie slewis's Avatar
    Nov 2006
    Washington
    On the note of manny tranny fluid, GM synchromesh fluid seems to be the stuff that ton's of people swear by, even the import crowd likes it. Anyways that's what I found out when I was researching to replace my fluid, and it has worked pretty well. Dunno if this helps but thought I'd share.
    Registered User The-Redneck's Avatar
    Mar 2010
    Red Deer, Alberta
    yeah man, take out the other crap, put in synchromesh.
    1995 GMC Sierra 2500 4x4 5.7L 5 speed manual W/T
    Im at home gettin hammerd nauticstar87's Avatar
    Jan 2010
    Danbury TX, Charleston SC
    Quote Originally Posted by tim-4878 View Post
    Holy Epic Thread Dig Batman!!!!!!!!!!!!!!!!!!!!
    2007 2500HD Silverado 2WD Regular Cab 6.0LY6 6-speed auto 4.10s, Super 44 Flowmaster, Blackbear Tune. Put some duct tape on it, and Screw you, I'm from TEXAS!!!
    Mar 2010
    Lyford, IN
    Just trying to research! Like every other site people don't always say what fixed the problem. Mine does it until i shift into 4th. 5th doesn't whine either. From looking around it seems a little whine is normal, just thought it was odd it only did it in 1,2,3 gears. I also have a little chatter when releasing the clutch that just started when I was driving it home. Just bought it today.
    I do plan to put synchromesh in it, might flush it with the pennzoil synchromesh then put the gm stuff after running it a bit.
    Jan 2010
    If you just bought it today, I'd suggest change all the fluids, trans, motor, diffs. changing the fluid in the trans may get rid of it.
    Mar 2010
    Lyford, IN
    yeah, i've already got $150 of making sure it's caught up on preventative maintanence. Just wanted to see if i had a new clutch/flywheel/bearings in my near future.
