Thread: 99 Tahoe lift ??
Results 1 to 11 of 11
    Apr 2006
    Maryland
    99 Tahoe lift ??
    Just bought 285/75/16 BFG A/Ts on Eagle 101s. Problem is the tires rub against the bumper and inner fender well. I was looking at a Trailmaster 3" lift. Question is can I get the same lift with new torsion keys and spring hangers ?? Any ideas ??
    Jan 2005
    dayton
    Re: 99 Tahoe lift ??
    Put a 1 inch block in the back, ford keys and level it out. Seen it done like that on a suburban, with 305 and 16 x 10. Will look good.
    Apr 2006
    Maryland
    Do I need Ford keys or will any aftermarket key work ? Will I need to adjust the TBs ? I saw a kit on e-bay for $140 for the keys and blocks.
    Jan 2005
    dayton
    Not too bad, but you can go to a Ford dealership and get keys for $50, then go to pep boys, autozone, or wherever to get a block for like 20. I odered a tapered 3 inch block with the u bolts for 70, plus fifty for the keys. But local auto place should have a block to satisfy you for around 20. I have a nbs, so i just replaced the factory 2 inch block with a three.
    Apr 2006
    Maryland
    Thanks 4 the info. What keys will I need from Ford ?
    Wheeler
    Jun 2004
    Houghton Mi
    Quote Originally Posted by Parritbay
    Look at the sticky thread at the top of the offroad forum. It will give you part numbers and instructions.
    has no car payment! TIMSPEED's Avatar
    Jan 2003
    Modesto, CA
    You should just be able to crank to get it level, and that'll do it..but I'm betting your rims have the wrong offset, which is causing the rubbing.
    -87 Corvette Z52 Coupe
    *K&N Filter,Yank Torque Converter,Custom Cat-Back
    -95 Tahoe 2-door 4x4
    *Posi-Lok/G80, 285's, Custom Cat-Back, 3.73's
    -96 S10 ECSB V6
    *ZQ8 Rims, 3" BellTech Drop, Dynomax Cat-Back
    Apr 2006
    Maryland
    Offset is 20mm backspace is 4", not sure what I am supposed to have ? I can pick up the Trailmaster kit w/shocks for ~ 450. Any feed back on Trailmaster??
    Jan 2003
    Modesto, CA
    4" Offset with how wide of a rim? 16x8 with 4" Offset should make them stick out enough to not rub...but 16x10 with 4" wouldn't be enough.
    -96 S10 ECSB V6
    Apr 2006
    Maryland
    Rims are 16x8. Tires are only rubbing while turning. I removed the plastic valance, but they still hit the bumper and inner fender. Dont really want to mess w/TBs
    Wheeler
    Jun 2004
    Houghton Mi
    those cheap lifts that are under 6" or 4" for rancho, so that means all the 3 inch lifts are junk i hear. Most will agree they are no better than cranking the torsion bars. serach for rancho or skyjacker or rough country 3 inch lift, they are all pretty much the same.
