Thread: Interior lights won't go off? I need some help!
Results 1 to 12 of 12
    Registered User 99Suburban's Avatar
    May 2005
    Wylie, Texas
    My wife drove our 1999 Chevrolet Suburban (obs) home the other night and the interior lights wouldn't go off, for anything. I tried everything, I even took the whole light control unit out, tore it apart, and it still doesn't work. Anyway, I ordered a new headlamp switch and the lights now won't go off unless we switch on the DOME OVERRIDE. Any help would be GREATLY appreciated.
    I've look at the Courtesy Lamps System schematics out of the HAYNES book and it appears that there is an INTERIOR LAMP CONTROL MODULE? Could this have gone out? And if so, where can I order one of these things? Thanks.
    1999 Chevrolet Suburban K1500 4X4
    1998 Chevrolet C1500
    ***PICS COMING SOON OF THE 1998***
    Dec 2002
    /home/andy
    Re: Interior lights won't go off? I need some help!
    could it be a bad door switch?
    Rest in Peace Jason Payne
    May 2005
    Wylie, Texas
    Quote Originally Posted by Whifflebat
    I suppose so, but how would I check that?
    Cape Cod
    When I had my Ford this happened from time to time. I went to the Ford site, and this was a common problem with them all the time.
    The fix was, Spray WD40 were the latch is when you open the door. Seems that the senor gets dirty and sticks.
    Well after 2 months of trying to figure it out and Ford telling me that I needed a $150 part put in I gave it a try, Worked like a Charm!!!
    Just open the door, spray in, open and close a few times and you are good to go. Do for each door. Mine was internment at first, and I figured out that it was the drivers side door.
    Give it a shot, Can't Hurt
    Good Luck!!
    2002 Chevy Silverado Z71, 4.8 4X4 EXT Cab, 3.73 gears(GT4). With 2" lift, via rear leafs from a 2500, & cranked T Bars
    Aug 2001
    New Jersey
    Quote Originally Posted by 99Suburban
    Open the drivers and pass door and look at the side of the dash. There wiill be a black "pecker" sticking out that you should be able to push in. Either that fell out and is constantly on or the switch itself is bad.
    islip ny (long island)
    i have been having this problem for a few months,i brought it back to the dealer and they told me it was the 30 second delay.
    i had the door switch replaced about a month ago and it solved the problem for a while.
    now it`s started up again but now when you push the window switch to raise the window when it is already closed,the interior lights will come on.
    same as you ,nothing turns them off but the dome overide button.
    i have a 99 yukon and others on this site have had the same prob.
    Lanark, Ontario
    Sounds like door switches.
    Can the temporary delay be turned off? That makes me crazy on new trucks.
    Registered User Blackfoot's Avatar
    Mar 2006
    California
    Quote Originally Posted by CKTA
    This fixed my problem a few years back. Check this first
    1988 k1500 RCSSB, 6" RCD, ORD Shackle flip, PA 3" BL, 15x10's w/ 35 x 12 MT Baja Claw Radials, Under Construction - never satisfied
    Beaner/Cracker Izzy's Avatar
    Aug 2001
    Fort Worth, TX
    :word: One of mine is broken but I always use the dome override.
    May 2005
    Wylie, Texas
    Thanks everybody. I haven't tried anything, but I will be trying most everything. I've been overworked the past couple of weeks and haven't had time to try anything.
    Dec 2003
    Seattle
    When you have the Dome Override depressed (to keep the light off), does the light go on when you use the remote keyless entry (RKE) keyfob to lock/unlock the doors? If that is the case, then the problem is likely in the RKE module, which is above your right foot when you are driving.
    There is a diagnostic routine in the Factory Service Manual which points to this, as has another person or two in the past here. I don't know, however, what the replacement part # is or its cost, as mine is also inop ('99 Yukon). Good luck (and if you find out the part #, please let us know!)
    Linus
    '99 Yukon
    Seattle, WA
    Homesick NBer
    Quote Originally Posted by Quyonmob
    i would like to know this, i keep my override on all the time and just turn the dome on when i need it, i hate that delay, when i close my doors it takes like 10 minutes for the light to shut off, i like the dome in my fathers 95 as soon as the door shuts the light goes off, but i had to get stuck with one that takes 10 minutes.
    2003 Chev Silverado 4x4 4.10 gears and it has a 4.8L:thud:
