Thread: Replace Window Regulator on 2002 Tahoe
Results 1 to 6 of 6
    Registered User 79Scottsdale's Avatar
    Jun 2004
    Oregon
    I want to know if it is difficult to replace a window regulator on the driver's side power window of 2002 Chevy Tahoe? The dealer wants 325 dollars to do it and I know I can get the part for a quarter of that amount plus the amount of beer I would be drinking during its installation.
    Any help or guidance would be appreciated. Thanks!
    -Nick
    1998 GMC Suburban
    Jan 2005
    tx
    Re: Replace Window Regulator on 2002 Tahoe
    im pretty sure this is very possible for you to do...im not sure if the regulater is the same thing as a motor is it?...or is the motor something completely different.
    Jun 2004
    Oregon
    I believe the motor is included in on the regulator as I have found them on E-bay fairly inexpensive. It is taking the door panel off the door that worries me.
    1998 GMC Suburban
    Feb 2002
    Dover, NH
    Quote Originally Posted by 79Scottsdale
    Did you end up doing this? I need to on a 2000 Silverado? was it difficult?
    2003 ECSB Silverado Z71 LT
    1990 Corvette ZR-1
    2005 Honda odyssey EXL (Wife's)
    Oct 2005
    Vancouver, WA
    Try this site:
    http://www.a1electric.com/s10motor.htm
    Shows a replacement, on an Chevy S10.....could be close to your Tahoe, situation.
    Aloha, Mark
    '95 Silverado ECSB, K1500, Z71, 4x4, 5.7L, TBI, 4l60e 4 spd auto trans, 3.73, G80, LT245/75R16, alum 6 lug wheels, 6 leaf springs on each side, 14 bolt rear, disc/drum (Code JB6-7200 lb rated), 6600 GVWR (Code C5S), HD chassis (Code F44).........basically stock.
    Jun 2004
    Oregon
    I took off the panel and found that taking it out was more difficult than I thought due to the regulator and motor being placed in a awkward position inside the door. You couldn't really get to it not unless you knew what you were doing and I did not know what I was doing. So I just took it to the dealership and they charged me $370.00 parts and labor. Although expensive, at least I knew it was done correctly. If you don't what you're doing, I wouldn't suggest replacing it yourself.
    1998 GMC Suburban
