Thread: roller rockers on vortec heads
Results 1 to 10 of 10
    Arkansas
    i have vortec heads on my 350 engine with the stock rocker arms. my cam is .480 lift cam on intake and exhaust and i would like to know what the best combination of roller rockers arms i should use? 1.6 on intake and exhaust or 1.5 intake with 1.6 on exhaust? thanks in advance for the input.
    technut
    Sep 2001
    north little rock, arkansas
    Re: roller rockers on vortec heads
    first, are these stock vortec heads?
    whats the application?
    modified springs?
    modified valve guides?
    airdeano
    ? horsepower
    ? torque
    will find out soon!
    1965 C10 5.3L (SSR) TH4L60e
    Registered User Joe87monteSS's Avatar
    Memphis, TN
    I'm sure you'll know you need the self alighning rockers. I run Scorpion full rollers, and they are perfect. I have no problems with them.
    Assuming your heads have NOT been modified, you are over their limit, if not cutting it close.
    However, if they are modified, I would use 1.6 on the exhaust, and 1.5 on the intakes.
    http://www.myspace.com/joe87montess
    2004 Silverado
    1987 Monte Carlo SS 383 ci.
    1985 S10 Tahoe 350/TH350 4.10's and a mini spool
    Bizzybone485
    Dec 2004
    Ocala, Florida, United States
    i dont mean to jac your post but im interested as well cause i will be going with a set as well when i get some vortecs installed this summer. I didnt know that you can mismatch rockers so id like some clarifying on this subject. I thought they had to match such as 1.6 and 1.6 as apposed to 1.5 and 1.6 on the same head. What performane difference does this do? I was gonna go with just some 1.6s but is there an advantage with going with an ofset like you guys are talking about? Thanks before and bump for a good post.
    91' RCSB Red Silverado on a 4/6 with Custom 355 ( .449 .456 212 218 112), Tbi mods, 65lb inj. /flowtech headers, 2.5 40-flowmaster,Tuned W/EBL Flash,Custom Bench http://www.cardomain.com/ride/2059169?poll_action=view
    Memphis, TN
    The 1.6 on the exhaust will allow for more lift, meaning more flow, since that valve is smaller. You've just got to make sure your Vortec heads are modified for the larger lift.
    2004 Silverado
    Not Enough Money 2manytoys's Avatar
    Dec 2005
    New York
    Quote Originally Posted by Joe87monteSS
    JoeMonte,
    Are the Scorpions self-aligning rollers? Mind telling me what part number they are? Thanks.
    97ChevyECSB,350,Dropped,All Poly,RearSwayBar,Headers,Flow50s,ZZ4Cam,ZEX,Nelson Hot Tune,915Beehives,1.6rollers,
    Port,Polish+Bowlblend,TBmods,plenumspacer,CAI,
    Built60E,3000stall,Transgo,MegaShifter+more.
    2004 Chevy CCSB 4x4 w/ K+N F.I.P.K, more to come
    1972 Pontiac LeMans 406cid
    Arkansas
    i did forget about the modification of the heads. what has to be done to them to allow more lift? is it something that can be done with them on the engine or must they be pulled? As far as springs go they have the z28 valve springs on them.
    Bizzybone485
    Dec 2004
    Yeah i defiantely will get vortec heads with upgraded springs as i have a 449/456 camshaft already and was planning on going with bigger rockers. How would the lift from 479/486 with both 1.6/1.6 change if i were to put 1.6 on the exhaust and 1.5s on the intake? Would this give me more lift overall or just on the exhaust but not on the intake?
    Woodstock Ontario Canada
    The Vortec heads dont flow very well compared to the intake. installing the 1.6's can help this a bit, as well as larger valves and porting.
    You can fit well ober 0.500" of lift on a vortec L31 head with no machining by using Compcams Beehive springs and retainers. These were originally built for LS1 use, but if you use the Compcams GEN1-E retainers(LS1 has different diameter valvestems).
    Springs are 26915 or 26918, installed heights are 1.8" for both, tehse springs are much better than the LT4 springs, although teh Beehives are quite pricey.
    If you dont want to pull the heads but want a higher lift cam with Vortec heads, its an option for sure.
    You need to pull the heads to elongate the stock pushrod hole as the 1.6:1 rockers bring the pushrod closer to the fulcrum(pivot) and will cause the pushrod to rub in the head.
    The vortecs like at least 10 degree in split between the intake and exhaust durations. I really like the LT4 Hotcam that is 218°/228° duration at 0.050" with 0.525"/0.525" on an 112°LSA.
    The lift comes down to 0.497" with the 1.5:1 rockers.
    peace
    Pauly
    Memphis, TN
    http://www.flatlanderracing.com/scor...chevySelfAlign
    Theres a list of part numbers.
    The heads need to be off the engine when doing that mod. I believe they cut the spring pockets, and trim the valve guides.
    2004 Silverado
