Thread: 4L60E Trans touble shooting guide
Page 1 of 3 123 LastLast
Results 1 to 20 of 44
    Mar 2006
    cincinnati
    Oil Pressure high or low (verify with gauge)
    Component:
    OIL PUMP ASSEMBLY
    check the pressure regulator valve
    the regulator valve spring
    a missing or miss assembled rotor guide
    a cracked rotor
    reverse boost valve/sleeve stuck or damaged or wrongly assembled
    orfice hole in pressure regulator valve stuck
    sticking slide or excessive rotor clearance
    pressure relief ball not seated or damaged
    porosity in pump cover or body
    wrong pump cover
    pump faces not flat
    OIL FILTER
    intake pipe restricted by casting flash
    cracks in filter body or intake pipe
    o-ring seal missing/cut/damaged
    wrong grease used during last rebuild
    VALVE BODY
    manual vavle scored or damaged
    spacer plate/gaskets incorrect/misassembled/damaged
    face not flat
    2-3 shift valve stuck
    checkballs missing or misassembled
    PRESSURE CONTROL SOLENOID
    SYSTEM VOLTAGE
    PRESSURE SWITCH ASSEMBLY
    CASE (case to valve body face not flat)
    possible codes:
    24 (VSS low)
    52 (VSS high)
    53 (system voltage too high)
    72 (VSS loss)
    73 (pressure control solenoid current)
    75 (system voltage too low)
    81 (2-3 shift solenoid circuit fault)
    82 (1-2 shift solenoid circuit fault)
    Mar 2006
    cincinnati
    Re: 4L60E Trans touble shooting guide
    Harsh Shifts
    COMPONENTS
    TPS
    VSS
    Pressure switch assembly
    Engine coolant temperature sensor
    Pressure control solenoid
    Possible codes:
    21 (TPS circuit high)
    22 (TPS circuit low)
    28 (FLuid pressure switch assembly fault)
    73 (Pressure control solenoid Current)
    Mar 2006
    cincinnati
    Inaccurate shift points
    COMONENTS
    OIL PUMP ASSEMBLY
    stuck pressure regulator valve
    sticking pump slide
    VALVE BODY ASSEMBLY
    spacer plate/gaskets misassembled, damaged, or incorrect
    CASE
    porus or damaged valvebody pad
    2-4 servo assembly (porosity, damaged seals, apply pin damaged/improper length)
    2-4 band assembly (burned, anchor pin not engaged)
    TPS
    damaged/disconnected
    VSS
    damaged/disconnected/retaining bolt not tightened
    4WD low switch
    disconnected/damaged
    Mar 2006
    cincinnati
    Early shifts
    POSSIBLE CODES
    69 (TCC stuck on)
    Mar 2006
    cincinnati
    Fixed shift points
    POSSIBLE CODES
    Mar 2006
    cincinnati
    1st Gear Range Only (no upshift)
    COMPONENTS
    VALVE BODY
    1-2 shift valve sticking
    spacer plate/gaskets mispositioned or damaged
    CASE
    case to valve body face not flat or damaged
    SHIFT SOLENOIDS
    stuck or damaged
    electrical connection
    2-4 SERVO ASSEMBLY
    restricted or blocked apply passages case
    nicks or burrs on servo pin/pin bore in case
    4rth servo piston in backwards
    2-4 BAND ASSEMBLY
    2-4 band worn or damaged
    band anchor pin not engaged
    Mar 2006
    cincinnati
    Slips in 1st Gear
    FORWARD CLUTCH ASSEMBLY
    clutch plates worn
    porosity or damaged forward clutch piston
    forward clutch piston inner and outer seals missing/cut/damaged
    input housing to forwad clutch housing o-ring missing/damaged
    damaged forward clutch housing
    forward clutch housing retainer/ball assembly not sealing or damaged
    FORWARD CLUTCH ACCUMULATOR
    piston seal missing/damaged
    piston out of it's bore
    porosity in the piston/valve body
    stuck abuse valve
    INPUT HOUSING AND SHAFT ASSEMBLY
    turbine shaft seals missing/damaged
    VALVE BODY
    1-2 accumulator valve stuck
    face not flat, damaged ring lands, or interconnected passages
    spacer plate/gaskets incorrect/missing/damaged
    LOW ROLLER CLUTCH
    damaged to lugs/inner ramps
    not free moving
    not enough spring tension
    damage to inner splines
    lube passage plugged
    TORQUE CONVERTER
    stator roller clutch not holding
    1-2 ACCUMULATOR ASSEMBPLY
    porosity in piston or accumulator cover/pin assembly
    damaged ring grooves on piston
    valve body to spacer gasket at accumulator cover missing/damaged
    leak between piston and pin
    broken 1-2 accumulator spring
    LINE PRESSURE
    2-4 SERVO ASSEMBLY
    Mar 2006
    cincinnati
    Slipping/rough 1-2 shift
    CONVERTER
    internal damage
    OIL PUMP
    stator shaft sleeve scored or off location
    VALVE BODY
    2-3 valve train stuck
    spacer plate/gaskets incorrect/misspositioned/damaged
    INPUT HOUSING ASSEMBLY
    clutch plates worn
    excessive clutch plate travel
    cut/damaged piston seals
    porosity in input clutch housing or piston
    3-4 piston checkball stuck, damaged, or not sealing
    restricted apply passages
    forward clutch piston retainer and ball assembly not seating
    sealing balls loose or missing
    CASE
    3rd accumulator retainer/ball assembly not seating
    2-4 SERVO ASSEMBLY
    2nd apply piston seals missing/damaged
    POSSIBLE CODES
    24 (VSS low)
    72 (VSS loss)
    Mar 2006
    cincinnati
    2nd and 3rd gears only OR 1st and 4th gears only
    POSSIBLE CODES
    SHIFT SOLENOIDS
    sediment/electrical connections
    Mar 2006
    cincinnati
    3rd Gear only
    POSSIBLE CODES
    52 (long system voltage high)
    53 (System voltage high)
    66 (3-2 control solenoide circuit fault
    75 (System voltage low)
    INSPECT
    system voltage
    Mar 2006
    cincinnati
    3-2 Flare or Tie Up
    INSPECT
    shorted or damaged
    Mar 2006
    cincinnati
    No 3-4 Shifts/Slipping or Rough 3-4 Shift
    INSPECT
    OIL PUMP ASSEMBLY
    faces not flat
    pump cover retainer/ball assembly missing or damaged
    VALVE BODY ASEMBLY
    valves stuck
    2-3 shift valve
    accumulator valve
    1-2 shift valve train
    3-2 control valve
    spacer plate/gaskets incorrect/mispositioned/damaged
    2-4 SERVO ASSEMBLY
    incorrect band apply pin
    missing/damaged servo seals
    porosity in pistons/cover/case
    damaged piston seal grooves
    plugged or missing orfice cup plug
    CASE
    3rd accumulator retainer/ball assembly leaking
    porosity in 3-4 accumulator piston or bore
    3-4 accumulator piston seal/seal grooves damaged
    plugged/missing orfice cup plug
    restricted oil passage
    *slipping 2-3 shift*
    2-4 BAND ASSEMBLY
    Worn or missassembled
    POSSIBLE CODES
    28 (Fluid pressure switch assembly fault)
    37 (Brake switch stuck on)
    38 (brake switch stuck off)
    67 (TCC solenoid circuit fault)
    Mar 2006
    cincinnati
    No Reverse or Slips in Reverse
    INSPECT COMPONENTS
    3-4 apply ring stuck in applied position
    forward clutch not releasing
    MANUAL VALVE LINK
    disconnected
    OIL PUMP ASSEMBLY
    stator shaft seal rings/ring grooves damaged
    stator shaft sleeve scored or damaged
    reverse boost valve stuck/damaged/misassembled
    cup plug missing
    faces not flat
    converter clutch valve stuck
    VALVE BODY ASSEMBLY
    manual link not adjusted
    spacer plate/gasket incorrect/mispossitioned/damaged
    low overrun valve stuck
    orficed cup plug restricted/missing/damaged
    REVERS INPUT CLUTCH ASSEMBLY
    clutch plate worn
    reverse input housing and drum assembly cracked at weld
    clutch retaining ring out of groove
    return spring assembly retaining ring out of groove
    seals cut or damaged
    porosity in piston
    bellville piston installed wrong
    oversided housing
    LOW AND REVERSE CLUTCH
    cluthc plates worn
    porosity in piston
    seals damaged
    return spring assembly retaining ring mispossitioned
    Mar 2006
    cincinnati
    No Part Throttle or delaed Downshifts
    2-4 SERVO ASSEMBLY
    servo cover retaining ring ommited or misassembled
    4th apply piston damaged or misassembled
    servo inner housing damaged or misassembled
    VALVE BODY ASSEMBLY
    3-2 downshift valve stuck
    4-3 sequence valve body channel blocked
    Mar 2006
    cincinnati
    Harsh Garage Shift
    VALVE BODY ASSEMBLY
    orifice cup plug missing
    checkball missing
    Mar 2006
    cincinnati
    No Overrun Braking - Manual 3-2-1
    INSPECT
    EXTERNAL LINKAGE
    inproper adjustment
    VALVE BODY ASSEMBLY
    4-3 sequence valve stuck
    checkball mispossitioned
    spacer plate/gaskets incorrect/damaged/mispositioned
    turbine shaft oil passages plugged/not drilled
    turbine shaft seal rings damaged
    turbine shaft sealing balls loose ormissing
    porosity in forward or overrun clutch piston
    overrun piston seals cut or damaged
    overrun piston checkball not sealing
    Mar 2006
    cincinnati
    No Torque COnverter Clutch Apply
    INSPECT
    ELECTRICAL
    12 volts not supplied to trans
    outside electrical connector damaged
    inside electrical connector/wiring harness/solenoid damaged
    electrical short (look for pinched solenoid wires)
    solenoid not grounded
    TCC SOLENOID
    ENGINE SPEED SENSOR
    CONVERTER
    inernal damage
    ENGINE COOLANT TEMPERATURE SENSOR
    OIL PUMP ASSEMBLY
    converter clutch valve stuck/assembled backwards
    converter clutch valve retaining ring mispositioned
    pump to case gasket mispositioned
    orfice cup plug restricted/damaged
    solenoid o-ring seal damaged
    high/uneven bolt torque (pump body to cover)
    TRANS FLUID TEMPERATURE SENSOR
    turbine shaft oring damaged
    turbine shaft retainer/ball assembly restricted/damaged
    BRAKE SWITCH
    VALVE BODY ASSEMBLY
    tcc signal valve stuck
    solenoid oring leaking
    SOLENOID SCREEN
    blocked
    POSSIBLE CODES
    21 (TPS high)
    22 (TPS low)
    52 (Long system voltage high)
    Mar 2006
    cincinnati
    Torque COnverter Clutch Shudder
    TORQUE CONVERTER ASSEMBLY
    internal damage
    OIL PUMP ASSEMBLY
    OIL FILTER
    crack in filter body
    flashing restricting filter neck
    o-ring seal damaged
    ALSO CHECK LOW OIL PRESSURE AND ENGINE TUNE
    Mar 2006
    cincinnati
    TCC apply with a Cold engine
    POSSIBLE CODES
    14 (engine coolant temp high)
    15 (engine coolant temp sensor low)
    Mar 2006
    cincinnati
    No Torque Converter Clutch Release
    TCC SOLENOID
    external ground
    clogged exhaust orifice
    CONVERTER
    internal damage
    VALVE BODY ASSEMBLY
    converter clutch apply valve stuckin apply position
    OIL PUMP ASSEMBLY
    PCM
    external ground
