Thread: 4L60E starts in 2nd
Results 1 to 15 of 15
    May 2006
    Ohio
    4L60E starts in 2nd
    I've got a '99 Silverado 4.3L with an automatic 4L60E transmission that all of the sudden lost 1st gear and overdrive (along with anything resembling power). It seems to start out in second, shift hard to third and stay there until I back down enough for it to shift back into second. Any ideas?
    Re: 4L60E starts in 2nd
    HAve you checked for codes stored in the computer? Does it start and run fine in park?
    Matching Ninja 500r
    Registered User 70chevrolet's Avatar
    Massachusetts
    Mine did the same thing. Tranny shop said it was cooked. I dont know $hit about trannies so I paid him $2000.00 for a rebuild...
    May 2006
    Ohio
    Mine's had this problem for a couple of months and now, all the sudden it's working again.
    Bigmike 61
    West Covina, CA.
    I had a 94 silverado that had the 4L60E and it did the exact same thing. I drove it that way for several months. I pulled the tranny and took it to a shop for an overhaul and when it came back it was still doing it. Come to find out it was one of the shifting solenoids. They informed me, afterwards, that the shift solenoids were not part of a normal overhaul. They changed the solenoid and it worked great. You can change the solenoids yourself, but I let them do it. Hope this helps.
    03' GMC Sierra 2500HD 4X4. Stock for now, but not for long.
    Feb 2007
    new mexico
    Does anyone know how many shift solenoids there are total in the automatic tranny? Anyone know the part numbers for these? thanks
    Oct 2005
    Huntsville, AL
    There are two shift solenoids. 1-2 and 2-3.
    They are the same part number, but I don't know what that is. Never had one go bad. If both have failed, you will only have 3rd gear. But you should be able to use the manual valve (i.e. the big lever beside the steering wheel) to overcome a broken shift solenoid.
    First hope to check for fault codes.
    My first thought was the "Sun shell gear" breaking. Do you still have reverse? Wait a second, did you ask a question, then post 4 days later that it fixed itself?!?! All while driving around with a 2 speed for a couple of months?
    Feb 2007
    new mexico
    Mine stays in third, seems like i can manually shift into one of the two lower gears. I can engage 1st or 2nd (i am not sure), then into third. I have scanned codes and came back with a code for shift solenoid a and b.
    Could this be the ignition parts everyone seems to have problems with?
    I still have reverse.
    Canuckastanie cpt. canuck's Avatar
    Jan 2007
    Toronto Canada
    Quote Originally Posted by tooredhots
    Found two on ebay for ya.
    http://cgi.ebay.com/ebaymotors/4L60E...QQcmdZViewItem
    Colt 6920/ AR15
    Noveske 16.1" barrel ,Timney target 3 lbs trigger,Colt new style m4 stock,ARMS S.I.R. rail,Trijicon ACOG TA31 sight,ARMS 40L back up sight,Vortex Flash Suppressor ,Knights ARMS Forward Grip,REDI-MAG Spare Mag Holder ,Surefire combat light,Laser sight
    and a GMC pickup too
    St. Paul, MN
    Just for the 1-2-3 shifts? 3
    367A, 367B, 394 are the shift solenoids in this diagram:
    Feb 2007
    new mexico
    Thanks to all! My problem is solved! I replaced my ignition switch and now everything works great! The best $94 I ever spent.
    St. Paul, MN
    Which switch did you replace exactly?
    Jan 2007
    PA
    I had the same thing happen to me and it was my ignition switch also.
    It would only happen occasionally, but I realized that if I started the truck and the PRNDL display did not light up, I would have the problem (starting in 2nd). If the PRNDL did light up, then it was fine.
    CleanRide04 spider's Avatar
    Feb 2007
    alaska
    Quote Originally Posted by 98GreenMachine
    Can you please tell me exactly what switch you replaced? My 04 is doing the same thing. Sometimes it starts in 2nd sometimes it is fine.
    Feb 2007
    new mexico
    I replaced the electronic portion of the ignition switch. I bought it from napa. The part number I believe is ECHKS6162.
