Thread: how to tell a 350 from a 305
Results 1 to 19 of 19
    arizona
    does anyone know of an easy way to tell a chevy 350 engine from a 305? - I just purchased an 89 shortbed I know the original engine isn't in it 'cause the owner told me, but he wasn't sure if a 350 or 305 was put in
    Locked and Loaded
    Ocala, FL
    Re: how to tell a 350 from a 305
    You might be able to get the serial number off the block and then contact GM.
    2004 Escalade, bone stock
    s10er8
    get the number off the front of the block, passengers side right in front of the head, post it here and somebody can tell you exactly what you have
    V8 S15 Jimmy member slammins15's Avatar
    Feb 2005
    canada
    Quote Originally Posted by s10er8
    There is NO casting numbers on the front of a block the casting number is on the back of the block behind the drivers side head right where the tranny bellhousing bolts up to plus about 4 inches to the right of the block casting it might have the displacment cast into it as well mine has 10054727 and 5.7 which is a tbi.
    s10er8
    Quote Originally Posted by slammins15
    I never said there was
    Registered User 454ss's Avatar
    Jul 2001
    Staten Island, NY
    click signature for pics
    90 454ss
    92 454ss
    08 Avalanche
    I wish people were like slinkys, fun to play with but when I get bored I can push them down the stairs.
    s10er8
    Ive got a 350 on my stand right now and a new engine under the bench. since you know everything about engines go take a look at one you have to verify there are numbers there......oh wait you probably don't. it's called a suffix code and has more information than a casting nmuber
    this is with the heads off but there's a number there
    edit:the head doesnt have to be off in order to see the number
    Registered User Mustangsaly's Avatar
    Nebraska
    Feb 2005
    canada
    Since you also know everything show me where on my TBI block there is any numbers stamped in my block in front of the passenger side head.
    Registered User jimbo92's Avatar
    Greenwood, SC
    the best way to tell is to floor it and see if its slow... but seriously like those other guys said about the only way to tell is the numbers on the block
    most unique username
    Oct 2001
    Bainbridge, NY
    Pull a sparkplug out, fill cylinder with sand. If it takes 38.125 cu.in. to fill, its a 305 - 43.75 cu.in. of sand and its a 350.
    :LOL:
    May 2005
    Hawaii
    Looks like that block was decked. (Looks just like the one in my V8S10)
    On OE blocks, the pad contains the codes indicated by other parties. (I also have an '87 TPI engine with the numbers stamped in that location)
    On the rear of the block(along the transmission bellhousing area) you may find a casting number, and on some later engines you may find displacement (5.0L, 5.7L) cast on the opposing side.
    There are a number of reference books you can purchase to identify what you have. You can also find internet references that will give you the same data.
    '12 FLTRXSE (my daily ride)
    '11 FLHRC (momma's)
    '01 Lexus GS430 (momma's)
    '94 RCSB DD for now
    '39 Ford Sedan Delivery
    Feb 2005
    canada
    That block was not decked was taken from an 89 truck and rebuilt.
    Euless, Texas
    Then it is there. Look right on the top of the pad that the water pump bolts to on the passenger side. There will be numbers there. I have 5 blocks in my garage ranging from mid 70s carbed to a late 90s vortec 350, all have numbers there.
    Feb 2005
    canada
    Seriously there is no numbers there so it was either
    1. decked without me knowing it when the machine shop bored it
    .020
    or
    2. Built on a friday at close to end of day and they forgot to stamp it.
    s10er8
    I think some engines do come through without the suffix code stamped, some crate motors maybe
    s10er8
    Congratulations you ran the guy off that needed help
    Feb 2005
    canada
    Yep it was all my fault.
    Florida
    Quote Originally Posted by ibthumpin
    :LOL:
    Awesome, now I've got a new weekend project. Check both of my 350's to make sure they are really 350s!!! Won't even have to buy the sand because my Florida yard is full of it. I better buy a chemistry beaker though.
    Quote Originally Posted by jimbo92
    Gotta love it. That's what I will do if I drink too much on Friday night.
    1997 Chevy Silvy Z71 Ext Cab 350
    2008 Chevy Corvette coupe
    Proud to be part of a family buying GM products since 1956
