Thread: Gas Pedal Sticking
Results 1 to 10 of 10
    Not Anymore
    New Jersey
    Gas Pedal Sticking
    I just got my truck back from getting worked on and i havent driven it in close to 3 weeks because the brake line was rotted out.. so i got it back today from getting work done and when i was driving it home the gas pedal would stick at like 1/4 throttle.. Is this just because i havent driven it in soo long and it needs to get worn in again?? or is it something else?
    Registered User 305ho's Avatar
    Apr 2006
    Hamilton Ontario
    Re: Gas Pedal Sticking
    That short of time would not make it stick. I would check the cable at the TBI and mounting bracket. The plastic sheild on the cable at the TBI end tend to crack an this could cause it to stick. If all looks good remove the cable from TBI likage and then check to se if cable moves freely back and forth. Also check that the butterflies on the TBI open and close all the way.
    Good luck.
    1991 ext-cab,short box silverado,5.7L,Edelbrock perfomer plus cam,Flow-master single inlet double outlet muffler, 4" chrome tips.ultimate tbi mods with 1.5 spacer. 4" Spectre polished aluminum dual intake plenum
    Resident FSC Canadian CHEV4LIFE's Avatar
    Sep 2004
    Toronto,Canada
    get a new truck:lol:
    check all your throttle cables:read:
    Dec 2005
    NW Arkansas
    I had this happen when I had a carb on my truck. If I remember right it was hitting the vent hose on the bottom of the air cleaner assembly or the base it self. It might be worth looking at.
    This is my 1986 Chevy C10. It has a GM 350 create motor with TPI and a 700r4.
    Florida
    Not sure if this is an option on your truck, but the butterfly valve in the throttle body might be getting stuck on carbon deposits. clean the throttle body and see if that helps.
    2006 Silverado Z71
    1987 Camaro IROC-Z with 13k miles
    - Luke 1989K1500's Avatar
    Jan 2005
    Ravenna, Michigan
    I did a big burnout before and let off the gas and the truck kept spinning the tire, I shut it off then moved the throttle and it was fine after that.
    Spray it with wd40 or somethin.
    Not Anymore
    New Jersey
    Quote Originally Posted by 1989K1500
    spray what with wd40 or somethin?
    I think its getting caught up on the K&N i gotta check tomorrow
    Dec 2005
    NW Arkansas
    Did you ever find out what was the problem?
    Gear-jamming nut redchevysport's Avatar
    Southern Missouri
    or a floormat. Blew up (for all intents and purposes) a 4.3 that way. pinned the gas pedal almost to the floor. makes for exciting takeofs though.
    1989 K1500 Sport 4x4 RCSB
    Swapped the 2nd 4.3L for a '93 burb 350
    And of course a 5-speed manny tranny
    "There'd be no truck drivers if it wasn't for us trucks, No double-clutchin', gear-jammin', coffee-drinkin' nuts"
    Not Anymore
    New Jersey
    Quote Originally Posted by shepherm
    the throttle linkage was hitting the bottom plate on the K&N filter. It was my to take off the air cleaner ring spacer because the K&N sat too low with it off. So i put it back on and haven't had a problem since then.
