Thread: Can I get some specs ??? 98 Vortec 350
Results 1 to 11 of 11
    Bellerose NY
    need some specs on a 98 Vortec 350 I'd like to know things like
    HP at what RPM
    TQ at what RPM
    Compression ratio
    Valve sizes
    valve spring specs
    Cam Specs
    Cylinder Head flow #'s & CC's
    what kind of pistons (flat, dome, dished)
    what material pistons(cast, forged, hyper-pathetic)
    what kind of crank and rods (forged, cast, nodular)
    Jul 2003
    Ft, Riley Ks
    Re: Can I get some specs ??? 98 Vortec 350
    HP at what RPM............. 255 @ 4000
    TQ at what RPM..............300 @ 2400
    Compression ratio.....9.6:1
    Valve sizes...........I'll have to look it up
    valve spring specs....I'll have to look it up
    Cam Specs.............I'll have to look it up
    Cylinder Head flow #'s & CC's...I'll have to look it up
    what kind of pistons.....(IICR) there flat
    what material pistons....(IICR) hyper-pathetic
    what kind of crank and rods....Forged
    Infantryman in the US Army
    technut
    Sep 2001
    north little rock, arkansas
    Valve sizes...........1.94" (I) 1.50" (E)
    valve spring specs....Installed Height 1.750" 80# closed 200# open
    Cylinder Head..... 64cc combustion chambers, 170cc intake runners
    68?cc exhaust ports, iron head
    what kind of pistons.....flat top/dished pressed wrist pins
    what material pistons.... cast aluminum
    what kind of crank and rods.... cast iron crankshaft
    powdered metal connecting rods.
    airdeano
    ? horsepower
    ? torque
    will find out soon!
    1965 C10 5.3L (SSR) TH4L60e
    Jul 2003
    Ft, Riley Ks
    Quote Originally Posted by airdeano
    airdeano
    Damn, at least I got 2 right.
    Woodstock Ontario Canada
    1996 250 hp @ 4600 rpm 330 lb/ft @ 2800rpm
    1997-2002 255hp @ 4600 rpm 330 lb/ft @ 2800 rpm
    cam specs
    192/197 duration @ 0.050" lift
    0.413"/0.427" lift with 1.5:1 rockers
    111 LSA
    9.4:1 compression ratio
    flow cfm
    intake 239 @ 0.500" valve lift
    exhaust 147 @ 0.500" lift open exhaust and 160 with pipe @ 0.500: lift
    Intake to exhaust ratio of 62% with open exhaut or 66% with pipe
    The pipe prevents shear at the exhaust port and is more representative of an actual exhaust port with a manifold or header installed.
    Plus all of Airdeanos info is correct. The L31 engiens used in the 2500 and 3500 trucks over 8600 lbs gvrw have 4 bolt mains.
    RnuovZ71, sorry to spoil your fun, the torque figure you posted was for a TBI 350.
    peace
    PAuly
    Gbodyolds is my biotch
    New Hyde Park, New York
    I'll give you some spec's
    It had enough power to move my hoe (both of them)so just put it in your pos and leave it alone!!!!!!
    lol
    30 psi of boost is like a hot chick with a std you want to hit it but are afraid of the consequences!
    http://www.myspace.com/454tahoe
    Bellerose NY
    har-de-har-har you must be really bored at work tonight
    Quote Originally Posted by Gbodyolds
    Different night, Still bored
    Jul 2003
    Ft, Riley Ks
    peace
    PAuly
    Im used to it pauly, I realy need to start looking out side the TBI's. LOL
    Bellerose NY
    Quote Originally Posted by 45**AHOE
    Bring some porn with you tommorow night and masturbate, that ill kill about 60seconds for ya, just be carefull you dont want to look like him.
    or you can
