Thread: Header bolt torque specs?
Results 1 to 8 of 8
    Nov 2004
    Arlington, Texas
    What do I torque the header bolts to on a gen III SBC with aluminum heads? 5.3L engine in 04 silverado.
    Thanks guys,
    Lurius
    Supporting Member doglip's Avatar
    Oct 2005
    Oklahoma
    Re: Header bolt torque specs?
    Quote Originally Posted by Lurius
    Thanks guys,
    Lurius
    Not sure about headers but the stock exhaust manifold is torqued to 11 ft/lbs first pass and 18 ft/lbs final pass. I suspect those specs world work on headers also? good luck
    Diplomacy is the art of saying 'nice doggy' until you have a hand full of chunkin rocks.
    04'-K2500HD-LQ4-Westers 93 HOT tune
    Nov 2004
    Arlington, Texas
    Now im just having problems removing the bolts holding the stock headers onto the stock Y pipe lol.
    -Lurius
    Virginia
    As I recall when I put my headers on a few months ago the directions said to torque to 15 pounds. It didn't say anything about a difference in heads.
    Have a nice day.
    Bill
    2005 Silverado 1500 LS 4x4 with Quadrasteer * BlackBear Performance Tune * 180 Thermostat * Airaid air intake * Dynatech Supermaxx headers with cats * Corsa dual side exit cat-back exhaust * 275/60/20 tires
    Registered User gmsuv's Avatar
    Michigan
    I think this will help.
    If not let me know
    Document ID# 1458398
    2004 Chevrolet Chevy C Silverado - 2WD
    Cylinder Head Installation - Left
    Tools Required
    J 42385-100 Head/Main Bolt Thread Repair Kit
    J 45059 Angle Meter
    Caution
    Refer to Safety Glasses Caution in Cautions and Notices.
    Notice
    Clean all dirt, debris, and coolant from the engine block cylinder head bolt holes. Failure to remove all foreign material may result in damaged threads, improperly tightened fasteners or damage to components.
    Important
    Do not use the cylinder head bolts again. Install NEW cylinder head bolts during assembly.
    Do not use any type sealant on the cylinder head gasket, unless specified.
    The cylinder head gaskets must be installed in the proper direction and position.
    Clean the engine block cylinder head bolt holes, if required. Thread repair tool J 42385-107 may be used to clean the threads of old threadlocking material.
    Spray cleaner GM P/N 12346139 (Canadian P/N 10953463), GM P/N 12377981 (Canadian P/N 10953463) or equivalent into the hole.
    Clean the cylinder head bolt holes with compressed air.
    Important
    First design engine blocks have different drill and tap depths using both medium length 100 mm (3.94 in) and long 155 mm (6.1 in) M11 cylinder head bolts. Second design engine blocks use only the medium length 100 mm (3.94 in) bolt with a common drill and tap depth.
    Measure the depth of the cylinder head bolt holes (1-10) and select the correct length bolts as required.
    Check the cylinder head locating pins for proper installation.
    Inspect the displacement markings (1) on the gasket, for proper usage.
    Important
    When properly installed, the tab on the left cylinder head gasket will be located left of center, or closer to the front of the engine.
    Install the NEW left cylinder head gasket onto the locating pins.
    Install the cylinder head onto the locating pins and the gasket.
    Install the NEW cylinder head bolts.
    Notice
    Refer to Fastener Notice in Cautions and Notices.
    Tighten the first design cylinder head bolts. Tighten
    Tighten the first design M11 cylinder head bolts a first pass in sequence to 30 Nm (22 lb ft).
    Tighten the first design M11 cylinder head bolts a second pass in sequence to 90 degrees using the J 45059 .
    Tighten the first design M11 cylinder head bolts (1,2,3,4,5,6,7,8) to 90 degrees and the M11 cylinder head bolts (9 and 10) to 50 degrees a final pass in sequence to using the J 45059 .
    Tighten the M8 cylinder head bolts (11,12,13,14,15) to 30 Nm (22 lb ft). Begin with the center bolt (11) and alternating side-to-side, work outward tightening all of the bolts.
    Tighten the second design cylinder head bolts. Tighten
    Tighten the second design M11 cylinder head bolts (1-10) a first pass in sequence to 30 Nm (22 lb ft).
    Tighten the second design M11 cylinder head bolts (1-10) a second pass in sequence to 90 degrees using the J 45059 .
    Tighten the second design M11 cylinder head bolts (1-10) a final pass in sequence to 70 degrees using the J 45059 .
    Michigan
    This will help also
    Document ID# 826358
    Exhaust Manifold Replacement - Right 4.8L, 5.3L, and 6.0L Engines
    Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
    Remove the exhaust manifold pipe nuts.
    Lower the vehicle.
    Remove the spark plugs. Refer to Spark Plug Replacement in Engine Controls - 4.8L, 5.3L, and 6.0L.
    Remove the exhaust manifold bolts, manifold, and gasket.
    Discard the gasket.
    Remove the heat shield bolts (1), and shield (2) from the exhaust manifold (1), if necessary.
    Clean and inspect the exhaust manifold. Refer to Exhaust Manifold Cleaning and Inspection .
    Installation Procedure
    Notice
    Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
    Install the heat shield (2), and bolts (1) to the exhaust manifold (1), if necessary. Tighten
    Tighten the bolts to 9 Nm (80 lb in).
    Important
    Tighten the exhaust manifold bolts as specified in the service procedure. Improperly installed and/or leaking exhaust manifold gaskets may affect vehicle emissions and/or On-Board Diagnostics (OBD) II system performance.
    The cylinder head exhaust manifold bolt hole threads must be clean and free of debris or threadlocking material.
    Important
    Do not apply sealant to the first three threads of the bolt.
    Apply a 5 mm (0.2 in) wide band of threadlock GM P/N 12345493 (Canadian P/N 10953488), or equivalent to the threads of the exhaust manifold bolts.
    Install the exhaust manifold, NEW gasket and bolts. Tighten
    Tighten the bolts a first pass to 15 Nm (11 lb ft). Tighten the bolts beginning with the center 2 bolts. Alternate from side-to-side, and work toward the outside bolts.
    Tighten the bolts a final pass to 25 Nm (18 lb ft). Tighten the bolts beginning with the center 2 bolts. Alternate from side-to-side, and work toward the outside bolts.
    Using a flat punch, bend over the exposed edge of the exhaust manifold gasket at the front of the right cylinder head.
    Install the spark plugs. Refer to Spark Plug Replacement in Engine Controls - 4.8L, 5.3L, and 6.0L.
    Raise the vehicle.
    Install the exhaust manifold pipe nuts. Tighten
    Tighten the nuts to 50 Nm (37 lb ft).
    Lower the vehicle.
    Document ID# 826358
    Nov 2004
    Arlington, Texas
    Wow, awesome, thats EXACTLY what I needed! Thanks man!
    -Lurius
    Jan 2015
    Virginia
    Refer to TSB #6-06-01-026. It is for New Exhaust Manifold Bolts and Torque Specs. Dated 22 DEC 2006 for Engines L59, LR4, LM4, LM7, LQ4, LQ9, LS1, LS6 GEN III VORTEC Engines.
    Unless your new new headers came with specs, I would refer to this.
    Summary:
    - Add GM High Temp, High Strength Threadlocker (P/N 12345493)
    -Tighten in two passes starting with the two center bolts and and then the rest, alternating from side to side while working towards the outside.
    -FIRST PASS: tighten to 89 in lbs
    -SECOND PASS: tighten to 15 ft lbs.
    -Done
