Thread: 04 silvarado is throwing a U1041 code.....
Results 1 to 8 of 8
    Sep 2006
    BURLESON, TEX
    U1041 - Loss of EBCM Communication. What the heck is this? (ebcm)
    Lifelong Chevy Man
    Florida
    Re: 04 silvarado is throwing a U1041 code.....
    Body Control Module? I have heard of that here, but no idea what it actually does.
    Document ID# 1734167
    2004 Chevrolet Chevy C Silverado - 2WD
    Subject: ABS Light On, DTCs C0265, C0201, U1041 Set and/or Loss of Communication with Brake Module (Reground EBCM Ground) #04-05-25-002C - (11/23/2005)
    Models: 2004-2005 Buick Rainier
    2002-2006 Cadillac Escalade, Escalade EXT
    2003-2006 Cadillac Escalade ESV
    1999-2006 Chevrolet Silverado
    2000-2006 Chevrolet Suburban, Tahoe
    2002-2006 Chevrolet Avalanche
    2002-2005 Chevrolet TrailBlazer, TrailBlazer EXT
    2003-2005 Chevolet SSR
    1999-2006 GMC Sierra
    2000-2006 GMC Yukon, Yukon Denali, Yukon XL
    2002-2005 GMC Envoy, Envoy XL
    2002-2006 GMC Sierra Denali
    2004-2005 GMC Envoy XUV
    2002-2004 Oldsmobile Bravada
    This bulletin is being revised to provide further diagnostic information and add 2006 model year full-size vehicles. Please discard Corporate Bulletin Number 04-05-25-002B (Section 05 -- Brakes).
    Condition
    Some customers may comment that the ABS light is on. Upon further inspection, DTCs C0265 and C0201 may be set in the brake module. It is also possible for DTC U1041 to set in other modules. There may also be a loss of communication with the brake module.
    Cause
    A poor connection at the EBCM ground is causing unnecessary replacements of brake modules.
    Important: The EBCM Ground is different for each application. Refer to the list below for the proper ground reference:
    • Midsize Utilities = Ground 304
    • SSR = Ground 400
    • Fullsize Trucks and Utilities = Ground 110
    Correction
    DO NOT REPLACE THE BRAKE MODULE.
    Perform the following steps to improve the connection of the EBCM Ground:
    Remove the EBCM Ground. The EBCM Ground is located on the frame beneath the driver's side door. If multiple grounds are found in this location, the EBCM ground can be identified as the heavy (12-gauge) wire.
    Clean the area, front and back, using a Whiz Wheel®.
    Install the ground, then the washer and then the bolt to the frame.
    Important: It is important to use the bolts, washers and nuts specified in this bulletin. These parts have been identified due to their conductive finish.
    Install a washer and nut to the back side of the frame.
    Tighten
    Tighten the nut to 9 N·m (79 lb in).
    Cover the front and back side of the repair area using Rubberized Undercoating.
    An additional check can be made to ensure a good connection for the Battery Cable to Frame ground. It is possible for this ground to cause similar symptoms with the ABS as described above.
    Parts Information
    FULL-SIZE TRUCKS, SUVs AND H2
    Part Number
    Description
    11588564
    Bolt
    15650962
    Washer
    15672934
    Nut
    12378398
    (in Canada, 10952414)
    Rubberized Undercoating -- Paintable
    MIDSIZE SUVs
    Part Number
    Description
    11517555
    Bolt
    15650961
    Washer
    11503749
    Nut
    12378398
    Warranty Information
    For vehicles repaired under warranty, use:
    Labor Operation
    Description
    Labor Time
    N9502
    Ground Repair - EBCM Ground
    0.2 hr
    GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
    WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
    © Copyright General Motors Corporation. All Rights Reserved.
    Sep 2006
    BURLESON, TEX
    Thank you for your help.
    Lifelong Chevy Man
    Florida
    p.hinds is a wonderful person.
    - Russ
    May 2005
    Hawaii
    Gonna go check mine tomorrow...
    '12 FLTRXSE (my daily ride)
    '11 FLHRC (momma's)
    '01 Lexus GS430 (momma's)
    '94 RCSB DD for now
    '39 Ford Sedan Delivery
    diehrd
    p.hinds rules....
    May 2005
    Hawaii
    Ground is not the cause of my problems... gonna pull the ABS module and send it to modulemasters.com
    '11 FLHRC (momma's)
    '94 RCSB DD for now
